Oil Filter cutting? what do you use?
Posted by: Flareside302
Oil Filter cutting? what do you use? - 02/15/14 08:34 PM
I'm looking to see what y'all use to cut filters open easily.
something reasonably priced but good and fast at cutting some thick cans open.
looking to cut open several as a comparison piece.
Posted by: Shannow
Re: Oil Filter cutting? what do you use? - 02/15/14 08:41 PM
Hacksaw
Posted by: Rand
Re: Oil Filter cutting? what do you use? - 02/15/14 08:53 PM
oil filter cutter,dremel, hacksaw
Posted by: 901Memphis
Re: Oil Filter cutting? what do you use? - 02/15/14 09:00 PM
This is a nice one.
http://www.jegs.com/i/Longacre+Racing/44...CFcY-Mgod7GEAfg
Posted by: Ramblejam
Rent an exhaust pipe cutter (chain type) from your local auto parts store
Posted by: 2015_PSD
Re: Oil Filter cutting? what do you use? - 02/15/14 09:04 PM
I use this one:
http://www.jegs.com/i/JEGS+Performance+Products/555/80532/10002/-1
Posted by: vssjim
Re: Oil Filter cutting? what do you use? - 02/15/14 09:22 PM
speedway motors sells a decent one
Posted by: KD0AXS
Re: Oil Filter cutting? what do you use? - 02/15/14 09:50 PM
Posted by: stro_cruiser
Re: Oil Filter cutting? what do you use? - 02/15/14 10:04 PM
http://www.harborfreight.com/exhaust-pipe-cut-off-tool-69327.html
Posted by: KCJeep
Re: Oil Filter cutting? what do you use? - 02/15/14 10:36 PM
Hacksaw and practice. Like the looks of that Harbor Freight cutter though.
Posted by: CHARLIEBRONSON21
Re: Oil Filter cutting? what do you use? - 02/15/14 10:45 PM
Yes. This is inexpensive and works just fine.
Posted by: ZeeOSix
Re: Oil Filter cutting? what do you use? - 02/15/14 11:13 PM
Originally Posted By: 2010_FX4
Many people here have that one, and they will all say it doesn't do small-ish diameter filters. The two wheel mounted in the end are too small & too far apart. If they would re-design it slightly is would work on smaller diameter filters better.
Posted by: DuckRyder
Re: Oil Filter cutting? what do you use? - 02/16/14 07:02 AM
You can get the Longacre Oil Filter Cutter from amazon for a bit more and it can be adjusted for smaller filters by moving the rollers. It does Honda filters with no issue, but I don't have anything smaller...
Posted by: Colt45ws
Re: Oil Filter cutting? what do you use? - 02/16/14 08:00 AM
I have this one too. I don't have anything smaller than a FL400S-size.
Posted by: nwjones18
Re: Oil Filter cutting? what do you use? - 02/16/14 09:01 AM
I use a 3in air cutoff tool. Have to be careful though I've set a filter on fire with it before.
Posted by: flstffxe
Re: Oil Filter cutting? what do you use? - 02/16/14 09:05 AM
Works like a charm. Done in about 15 minutes with parts on hand.
Posted by: Sayjac
Re: Oil Filter cutting? what do you use? - 02/16/14 09:29 AM
See post in thread below. Depends on how much you want to spend and purpose. I've found the HF exhaust cutter to be cost effective, and fairly good with some finesse applied.
http://www.bobistheoilguy.com/forums/ubb...lte#Post3174892
Posted by: 2015_PSD
Re: Oil Filter cutting? what do you use? - 02/16/14 11:20 AM
How small? The oil filter for my Kawasaki Brute Force 750 is 2.65" in diameter and it cut it open just fine.
Posted by: BlueOvalFitter
Re: Oil Filter cutting? what do you use? - 02/16/14 01:52 PM
Posted by: DBMaster
Re: Oil Filter cutting? what do you use? - 02/16/14 01:56 PM
^I have one of those. How do you cut open an oil filter with it?
Posted by: laserred96gt
Re: Oil Filter cutting? what do you use? - 02/16/14 02:07 PM
those ridgids go only up to 1"1/8 I think, I use bigger pipe cutters for small diameter filters, and sawzall for bigger filters.
Re: Oil Filter cutting? what do you use? - 02/16/14 02:12 PM
You need one of these to use those cutters; crackmeup
Re: Oil Filter cutting? what do you use? - 02/16/14 02:24 PM
Ok, ok, seriously, I use a Dremel. My son in FL. has my Ridgid pipe cutters that cut 2-1/8" OD to 4-1/2" OD pipe.
I was just having a little bit of fun with BITOG members. smile
Posted by: ZeeOSix
Re: Oil Filter cutting? what do you use? - 02/16/14 02:35 PM
Mine won't quite do a Classic L14610, which is 2.70" diameter.
http://www.purolatorautofilters.net/resources/Popup/Pages/PartDetailPopup.aspx?partnum=L14610
Maybe they changed the design slightly - how long ago did you buy yours. Mine is maybe 3 years old now.
Posted by: DBMaster
Re: Oil Filter cutting? what do you use? - 02/16/14 03:14 PM
You got me! I thought maybe there was some secret method. I recently inherited a Dremel tool set and tried cutting open of my used Skyactiv filters. Based upon how long it took to make a single penetrating cut I think it could take thirty minutes to open up a filter. Which attachment do you use? I tried a 1/32" cutting wheel.
Re: Oil Filter cutting? what do you use? - 02/16/14 03:21 PM
That's what I use. I usually use 2 wheels and about 30 minutes to cut open a filter. Taking this much time does not bother me. I have nothing else to do.
But, I tried cutting open a FRAM XG43 with my Dremel but the can is too thick. I have a Dewalt 4.5" grinder and a Bosch 4.5"X .040" cutting wheel I will use on it. thumbsup
Posted by: DBMaster
Re: Oil Filter cutting? what do you use? - 02/16/14 03:23 PM
I think the Tokyo Roki Skyactiv filter must be too thick as well.
Posted by: Sayjac
Re: Oil Filter cutting? what do you use? - 02/16/14 06:07 PM
Perhaps the JEGS model has narrowed the distance between the guide wheels, but for the Summit anything ~3" or less doesn't hit the wheels and basically rubs the the cross bar, many show worn black paint in the center area. It will cut but not with a smooth action. The pic below show an example on a now discontinued AAP Total Grip 7317 which would the same diameter as the PL/L 14610.
OT, The AAP TG was a really good value Puro variant and a Bitog favorite, especially on bogo and closeout. Had a nice stash of them that I used up. First dissected filter I ever posted was an AAP TG posted in this thread was a Total Grip, and another in this thread.
Posted by: Colt45ws
Re: Oil Filter cutting? what do you use? - 02/16/14 07:29 PM
Seems like you could make a notch on the cross bar to allow the filter closer access.
Posted by: Colt45ws
Re: Oil Filter cutting? what do you use? - 02/16/14 07:37 PM
Okay, nevermind that wont work. Its solid there and where that section bolts to the bar. I tried a FL400 again and I do see that it rubs on the center section pretty good. They obviously were not thinking of filters smaller than a PH5/8/2.
Posted by: Sayjac
Re: Oil Filter cutting? what do you use? - 02/17/14 07:32 AM
And that's why I gave with relatively inexpensive HF exhaust cutter a shot. It has four cutting wheels and with some technique experience it does a reasonably good job.
I'm curious to know if the linked Jegs model has improved on the Summit design by moving the guide wheels closer together.
Posted by: EricF
Re: Oil Filter cutting? what do you use? - 02/17/14 12:23 PM
I got mine from Summit racing a while ago, it was $45, basic looking, but it works.
I have problems cutting into Wix & purolator filters tho..
it eats thru fram & bosch's like nobody's business.
Posted by: paulo57509
Re: Oil Filter cutting? what do you use? - 02/17/14 10:38 PM
I use on of these:
http://www.amazon.com/Longacre-Oil-Filte...l+filter+cutter
This one doesn't work on very small diameter filters either.
I'm pretty sure it can be modified to work with small diameter filters by swapping out the bearings with ones with a larger OD.
Posted by: ZeeOSix
Re: Oil Filter cutting? what do you use? - 02/18/14 12:43 AM
Originally Posted By: paulo57509
I use on of these:
It doesn't cut smaller filters even if you move the two posts the bearings are on inward toward the cutter?
Posted by: Clevy
Re: Oil Filter cutting? what do you use? - 02/18/14 02:36 AM
I've been using my sawzall however I think the best bet would be a cast pipe cutter with the cutting wheels
Posted by: Sayjac
Re: Oil Filter cutting? what do you use? - 02/18/14 05:44 AM
I use on of these:
This one doesn't work on very small diameter filters either.....
Based on it's appearance I've long thought the Longacre was the creme dela creme of filter cutters. But if it doesn't work on smaller diameter filters I wouldn't pay that kind of money for it. Just me.
Originally Posted By: Clevy
.... I think the best bet would be a cast pipe cutter with the cutting wheels
This may or may not be applicable, but a poster or two tried to use the Harbor Freight pipe cutter with little success. They ended up crushing the can(s) more than cutting it open.
Re: Oil Filter cutting? what do you use? - 02/18/14 06:07 AM
I use on of these:
Define "very small"?
That is the exact one I have and it would defiantly do smaller than Honda Filters - you know you can move the rollers to the inner set of holes correct?
Re: Oil Filter cutting? what do you use? - 02/18/14 06:02 PM
I use on of these:
Must be a new model. I didn't notice the extra holes. Mine doesn't have them.
Re: Oil Filter cutting? what do you use? - 02/18/14 07:10 PM
Hmm, next time I am near mine I will snap a picture... unless I imagined the whole thing (and anything is possible) mine has another set of holes in it...
Ahh, see here:
http://www.gtsparkplugs.com/Oil_Filter_Cutter.html
and:
Posted by: ZeeOSix
Re: Oil Filter cutting? what do you use? - 02/18/14 07:21 PM
I use on of these:
Get out a drill and bit that's the same size as the current holes and put in another set of holes like on the newer model for the roller bearings. Seems like it would be very easy to do.
Posted by: Arctic388
Re: Oil Filter cutting? what do you use? - 02/20/14 10:00 AM
https://www.youtube.com/watch?v=bguOzI2ChLs
i have the longacre filter cutter and it has 4 holes for adjustment. i really like using it.
https://www.youtube.com/watch?v=QrLIf2u0NiQ
this one shows the cutter a little clearer.
Posted by: George7941
Re: Oil Filter cutting? what do you use? - 02/27/14 06:57 PM
I use a pipe cutter
Posted by: derweed
Re: Oil Filter cutting? what do you use? - 02/27/14 09:14 PM
I use the Harbor Freight exhaust cutter. It works really well. I have used it on the smaller filters of wife's CRV and on the Motorcraft FL500 for my F150
