Adding Lubro Moly Oil saver will increase grade?
Posted by: Yannick
Adding Lubro Moly Oil saver will increase grade? - 04/25/14 03:13 PM
Hi,
By adding one can of Lubro Moly Oil saver in 5liters of 10w30 , will change the grade to what approx? 15w40?
thks
Posted by: dave5358
Re: Adding Lubro Moly Oil saver will increase grade? - 04/25/14 04:24 PM
Originally Posted By: Yannick
Hi,
Liqui Moly Oil Saver (fka Lubro Moly Oil Saver) shouldn't change the grade at all. From the manufacturer's website, it says:
Regenerates rubber and plastic engine seals such as shaft seals and valve stem
seals and prevents oil stains under the vehicle. Counteracts oil dilution. Reduces
engine noise and oil consumption through piston rings and valve guides.
It swells rubber seals or at least makes them more pliable.
You may be thinking of Motor Honey or STP?
Posted by: Falcon_LS
Re: Adding Lubro Moly Oil saver will increase grade? - 04/25/14 05:44 PM
Motor Oil Saver is an ester-based additive. It will thicken up the oil slightly, but nothing major.
Posted by: Yannick
Re: Adding Lubro Moly Oil saver will increase grade? - 04/25/14 05:52 PM
10-4 Boss !!!
Posted by: 147_Grain
Re: Adding Lubro Moly Oil saver will increase grade? - 04/25/14 05:59 PM
A VOA of Lubro Moly a few years ago showed viscosity characteristics similar to a 5W-30.
Here's an example from 2008 VOA:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1234989
Posted by: dailydriver
Re: Adding Lubro Moly Oil saver will increase grade? - 04/25/14 06:12 PM
We are talking about the Motor Oil saver in this thread, NOT the MOS2.
The Motor Oil Saver IS one of the most viscous additives I've ever seen anywhere (even more so than the old VSOT stuff), but, as has been stated, adding 300ml of it to 5+ quarts of oil will not do much to change the HTHSV, nor the cSt @100*C. wink
Re: Adding Lubro Moly Oil saver will increase grade? - 04/25/14 06:26 PM
Oops! frown
Posted by: Yannick
Re: Adding Lubro Moly Oil saver will increase grade? - 04/25/14 08:33 PM
got it !
Posted by: HTSS_TR
Re: Adding Lubro Moly Oil saver will increase grade? - 04/26/14 10:33 PM
What I observed is different with yours, VSOT is much thicker than Lubro Moly Oil Saver.
Re: Adding Lubro Moly Oil saver will increase grade? - 04/27/14 04:08 PM
You are probably correct on this as I have not handled the VSOT product in MANY years now, and have forgotten just how 'frozen molasses-like' that stuff was. wink LOL
