Hyper-Lube oil additive
Posted by: Durango
Hyper-Lube oil additive - 02/28/10 09:11 PM
Hey guys/gals,
Ever use it????? Comes in a small clear bottle that looks just like water.
Durango
Posted by: postjeeprcr
Re: Hyper-Lube oil additive - 02/28/10 09:23 PM
Are you talking about the Hy-per Lube ZRA Additive? Their oil supplement is not clear. I have not used the ZRA but according to the label is has esters which is interesting. A guy at a local auto parts store told me it is good stuff, they got some in I guess and sold out of it....lol
Posted by: Durango
Re: Hyper-Lube oil additive - 03/01/10 09:31 AM
postjeeprcr,
No this stuff is clear liquid in a small bottle.
Just wondering.
Durango
Posted by: axjohn
Re: Hyper-Lube oil additive - 03/01/10 03:30 PM
I used a product called Hyper-Lube when I lived in Columbus, Ohio in the eighties and nineties. The product claims to have--at least the one I used claime to have--jojoba oil in it.
There were a couple of formulas available, one "regular" and one "premium" (the Premium cost a buck more per quart). Bought the product at Meirs (Meyers?) in Dublin, Ohio.
It sure SEEMED to work in my 4-banger 1988 Acura integra. I used it in the manual transmission (shifted smooth as silk after that) and a little less than a quart in the oil. Like I seem, engine was smoother, and it sure seemed like I got a little better acceleration.
Supposedly, jojoba oil is pretty slippery. Maybe one of the resident tribologists can chime in on it's chemistry.
Maybe using it in the oil helped balance the compression between cylinders so it SEEMED more powerful. I know it was definitely smoother, quieter, and shifted slicker than (fill in the blank), even in below zero weather.
Posted by: dailydriver
Re: Hyper-Lube oil additive - 03/01/10 05:30 PM
Originally Posted By: Durango
postjeeprcr,
Just wondering.
Durango
That's what post was saying, that this stuff (Hy-Per Lube Zinc Replacement Additive) is the ONLY clear Hy-per Lube product in a small bottle.
It does sound interesting. I just read on their site that it contains NO ZDDP at all! (I thought it was just another ZDDP additive, like Red Line's/RP's/etc. when I'd seen it on Pep Boys' shelf.)
I'm going to call their tech dept. and see if they'll tell me whats in it (and not just cop-out with the tired, old standard, "proprietary info" response) besides said esters.
Boron, maybe???
Re: Hyper-Lube oil additive - 03/02/10 03:22 AM
postjeeprcr,
Just wondering.
Durango
Boron, maybe???
Let us know what you find out.
Re: Hyper-Lube oil additive - 03/02/10 06:56 PM
The tech called back today, and said that this stuff contains NO; ZDDP (we already knew that), moly (in ANY form), boron, antimony, calcium, or any other 'typical' anti-wear, anti-corrosion type elements/compounds.
He stated that it was just pure friction reducing, anti-wear esters (he did not, nor would not say what type of esters), made to act as (and take the place of) the above sacrificial elements (especially ZDDP for older flat tappet designs) would.
I wonder if it is the same esters as in the Lube Gard engine oil supplement??
Posted by: axjohn
Re: Hyper-Lube oil additive - 03/02/10 10:07 PM
I wonder if jojoba oil contains, or can be, "esterized" to produce a low friction additive. I clearly remember seeing jojoba oil mentioned on the hyperlube products i used.
They also showed a with and without comparative horsepower comparison over the idle to 7 or 8k rpm range, with a clear advantage throughout the rpm range for the addition of the hyperlube. IIRC, the standard product showed about a 4 hp consistent gain throughout the range, and the premium product showed a 7 or 8 hp gain throughout that same range. And this for a 4 cylinder engine of about 2 liters or so.
This was 20 years ago, so I don't have an empty container to post a piture of ("BAD BITOGER, no photo!).
Probably hyperlube.com or something of the sort.
Maybe dailydriver could follow-up with the tech dept to inquire about the possible jojoba connection. I know the product clearly made a difference in my 1988 Acura Integra 5sp.
Re: Hyper-Lube oil additive - 03/04/10 12:03 AM
I have talked briefly to Molakule about this product and he said they are olefin copolymer esters. I mixed some stuff in a bottle and it did something I had never seen before, so I sent him a pic. I do not know this but I would think it is different esters then in LubeGard.
Also the jojoba is in the "racing" version of the supplement which from labels seems exactly like the regular stuff except for the jojoba.
Posted by: axjohn
Re: Hyper-Lube oil additive - 03/04/10 10:28 PM
"I mixed some stuff in a bottle and it did something I had never seen before, so I sent him a pic."
So what exactly did this stuff do that surprised you so much that you took a picture and sent it to Molakule? Like I said, I've used it, and felt it was worth it, so I'd be interested in what you have to say on this!
Thanks.
Posted by: axjohn
Re: Hyper-Lube oil additive - 03/12/10 11:16 PM
Still no answer?
Found pictures of the product I used via google. Also found the MSDS:
http://www.hyperlube.com/documents/MSDSHPL302.pdf
Can you elucidate on your comments, postjeeprcr, unless the conversation between you and Molakule was private and not for forum consumption?
Thanks,
Re: Hyper-Lube oil additive - 03/13/10 01:23 AM
Thanks.
Was the stuff you used the Racing Supplement or was it the ZRA stuff? The stuff that surprised me was the ZRA, and it was informative why it congealed, lack of dispersants in the additive and what I mixed it with. I will have to look for the pic, when I find it I will show you.
Posted by: ARCOgraphite
Re: Hyper-Lube oil additive - 03/28/10 12:38 PM
I just saw the ZRA at pep boys when looking for MT gear lube. It was crystal clear/transparent in a clear bottle with a big ZINC on the label (and a small replacement under the zinc) and said on the back it contained polymer esters and NO converter damaging additives. I think it also said it could show 4x less cam wear than traditionl ZDDP additives. I think it was 15 bucks a pint or less $$$.
Re: Hyper-Lube oil additive - 03/28/10 12:54 PM
HY-perlube ZRA AD
Re: Hyper-Lube oil additive - 03/28/10 03:29 PM
Yes, that's what we are talking about. ^^^
Just waiting on post's pics to see the funny reaction this stuff had in solution (even though the label claims it is miscible/compatable with EVERYTHING out there (including other ester based synthetic oils).
Re: Hyper-Lube oil additive - 03/29/10 08:43 AM
It reads a lot less like snake oil than MOST snake oils - I'm intrigued. It is very viscous though.
Posted by: axjohn
Re: Hyper-Lube oil additive - 03/29/10 10:18 PM
Post the picture!
Posted by: axjohn
Re: Hyper-Lube oil additive - 03/29/10 10:49 PM
please.
Posted by: Skid
Re: Hyper-Lube oil additive - 06/22/11 07:28 PM
I can add a little bit to what has been posted before.
This product appears to be made out of Ketjenlube 135. If you download the MSDS from hyperlube's website, the title of the pdf (under file--->properties) states "9233 KETJENLUBE® 135 (English (US)) AKZO USA"
Ketjenlube is a brand name, and Akzo is the manufacturer.
It's quite viscous. It's briefly described in passing in U.S. Patent Application Publication No. 20090163393, which states:
"[0049]In one embodiment, the ester base stock for use herein is "Ketjenlube 135" a butanol ester of an α-olefin maleic acid copolymer having an Mn of 1800 and a viscosity of 35 cSt at 100° C."
There was some brief discussion about Ketjenlube 135 earlier here: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1173617
Other: I saw some comments about Ketjenlube 230, which is described as a low polar version of Ketjenlube 135 for better compatibility, which obviously means that K 135 might not be that compatible with everything.
I will guess that it's probably a good product but expensive, probably does what it purports to do (for how long, I have no idea), and will make your oil more viscous, which can be bad if you're someplace really cold. I'm curious enough to give it a shot.
Posted by: Skid
Re: Hyper-Lube oil additive - 06/22/11 08:47 PM
Further to the previous post, here is a link to some data regarding Ketjenlube:
http://www.italmatch.it/cm/articoli/Arese%20brochure%2001.pdf
The wear data in the above PDF is identical to that quoted by Hy-per lube.
Also, an alternative to this stuff may be to simply buy GC (German Castrol), which might be loaded with some form of Ketjenlube (I'm not sure).
Posted by: gotek
Re: Hyper-Lube oil additive - 06/26/11 12:03 PM
I have a quart and 1/2 of the Hyperlube Racing that I bought at a discount a while ago and am finding use as a power steering leak fixer at a 1 to 4 ratio (20%) of HL to ATF. Works better than Lucas PS stop leak.
