replaced raidiator...still smell coolant..no leaks
Posted by: Mark72
replaced raidiator...still smell coolant..no leaks - 02/18/14 03:59 PM
I guess the subject speaks for itself. I own a 2001 Nissan Sentra 2.0. Had a new radiator put in it 3 weeks ago. No leaks, all clamps are working and no moisture around any of the hoses but when I shut the car off after a drive I still smell coolant on the outside of the car. When I open the hood, it confirms it because that is definitely what Iím smelling but nothings leaking and I donít know what to do. Any ideas? Would it take 3 weeks for residual to burn off?
Posted by: Drew99GT
Re: replaced raidiator...still smell coolant..no leaks - 02/18/14 04:07 PM
Coolant can stick around and stink for a while. If your Sentra has splash shields underneath, it can puddle up and take a while for the water component to evaporate and /or for the coolant to get splashed out of any crevices/nooks/crannies from driving. As long as the level stays normal and no visible coolant is leaking, you should be good to go.
Posted by: Mark72
Re: replaced raidiator...still smell coolant..no leaks - 02/18/14 04:10 PM
Well that was my thought to..but Iíve had the car on several highway trips since the radiator was replaced 3 weeks ago. Would that not have burn it off by now?
Posted by: Warstud
Re: replaced raidiator...still smell coolant..no leaks - 02/18/14 04:12 PM
Have you checked the coolant level? If it's low it may be a bad Intake Manifold Gasket.
Posted by: Mark72
Re: replaced raidiator...still smell coolant..no leaks - 02/18/14 04:17 PM
Thought of that too...so I been checking the oil and it looks fine...no discoloration at all.
Posted by: Warstud
Re: replaced raidiator...still smell coolant..no leaks - 02/18/14 05:27 PM
Did you smell coolant prior to replacing the rad? And why did you replace the rad?
Posted by: MolaKule
Re: replaced raidiator...still smell coolant..no leaks - 02/18/14 06:01 PM
Take off the shields and go to a manual car wash and spray the engine compartment with soap and rinse thoroughly.
Let it dry and check for any new coolant leaks.
Sometimes the hose clamps need re-tightening or replacement.
