Castrol Edge 10w-60, 14k,'09 BMW M3
Posted by: brian_fantana
Castrol Edge 10w-60, 14k,'09 BMW M3 - 03/14/14 09:38 PM
I know my lead is high at 18. I'm hoping my switch to castrol 0w40 will improve my lead count. Other M3 drivers have switched to a 0w40 oil and cut their lead levels in half. I'm going to pull a sample at 5k and see if my numbers improve.
Code:
Oil Castrol      10w-60
Miles in use     14k
Miles            42k
Sample Taken     3/14/14
ALUMINUM	7
CHROMIUM	0
IRON	        11
COPPER          4
LEAD	        18
TIN	        0
MOLYBDENUM	150
NICKEL       	0
MANGANESE	1
SILVER        	0
TITANIUM        29
POTASSIUM	2
BORON     	28
SILICON     	5
SODIUM      	5
CALCIUM    	2480
MAGNESIUM	176
PHOSPHORUS	786
ZINC         	922
BARIUM     	0
SUS Viscosity @ 210F	91.6
cSt Viscosity @ 100C	18.37
Flashpoint in F	415
Fuel %	                <0.5
Antifreeze %	         0.0
Water %	                 0.0
Insolubles %	         0.1
TBN	                 2.5
Posted by: dparm
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/14/14 09:41 PM
When you say Castrol Edge 10w60, which one are you talking about? There's Castrol Edge Sport and Castrol Edge Professional TWS.
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/14/14 10:02 PM
Edge professional. I may need to edit that for clarity.
Posted by: 147_Grain
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/14/14 10:04 PM
That 10W-60 is one thick oil to use over the winter months. Agree that a 0W-40 is more appropriate to help you "get the lead out".
Posted by: HTSS_TR
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/14/14 10:30 PM
Thicker oil doesn't mean it protects the engine better than correct grade(thinner oil)
Posted by: jigen
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/14/14 11:10 PM
Was any make-up oil added? How long was the oil in use?
Posted by: jaj
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/15/14 12:28 AM
Castrol Edge or TWS 10w-60 is the only "correct" oil for this engine.
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/15/14 12:35 AM
Yes, I added 2qts of 10w60 edge pro in 14k.
Posted by: 901Memphis
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/15/14 12:39 AM
18 lead ain't too bad. What about Mobil 1 0W40?
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/15/14 01:26 AM
Probably a better oil from all I've read than castrol. To be honest I bought off on "designed for BMW" castrol advertises and feeling a bit of remorse after reading more comps. after I pulled the trigger. Just really hoping to cut those lead levels in half or more.
Posted by: Gokhan
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/15/14 05:07 AM
Interesting that high viscosity caused higher bearing wear -- opposite of what you would think. I wonder if that was because the oil flow was insufficient due to high viscosity.
Could it also be that OCI was too long and TAN got to high, causing bearing corrosion? TAN increase is strongly correlated with lead corrosion and wear. I emphasize that TBN alone is fairly useless to determine used-oil condition and both TBN and TAN are needed. Unfortunately Blackstone misleads people to believe that knowledge of TBN is sufficient.
Here is some previous discussion. See the Chevron/Oronite reference linked there as well:
TBN, TAN, Ca, Mg, base-oil quality, oil life
Posted by: dparm
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/15/14 09:10 AM
In North America, BMW now allows LL-01 oils in the S65. Many of us have switched to Mobil 1 0w40.
Posted by: Gokhan
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/15/14 08:13 PM
I can't imagine any modern gasoline road engine requiring anything thicker than M1 0W-40 SN, which has 3.8 cP HTHSV.
Posted by: nickolas84
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 03/16/14 11:51 AM
Make that, LL-01 is the only correct oil for this engine.
Posted by: Jtgrant
Re: Catrol Edge 10w-60, 14k,'09 BMW M3 - 04/20/14 10:01 PM
If you aren't tracking this car a lot with really high oil temps, the Mobil1 0w-40 is a great alternative. Even if you track the car with the Mobil1 0w-40 it is still a great choice. I would also recommend using the Mobil1 15w-50, especially when you can catch the Mobil1 on sale. I'm a BMW Master Tech, the S65 engine is extremely reliable mechanically. The only issues we really see is the low pressure fuel sensor failures, idle actuators and throttles failing. Other than that, they are really well made engines. It is crazy how bad our non M V8s are compared to the Motorsport V8 engines. The S62 and S65 are the best production V8s BMW has ever made. I really do not like seeing that the new generation M3/M4's will have turbo charged Inline 6 engines. Don't get me wrong I love inline 6 BMW engines, but we all know BMW has a lot of issues with turbo chargers and our High pressure fuel systems.
