How to post used oil analysis results
Posted by: wwillson
How to post used oil analysis results - 01/30/11 12:44 PM
All,
Please post oil brand/grade, oil miles, vehicle miles in subject line.
Posting images is discouraged because links tend to break over time.
We prefer that you use a code block because the text remains aligned in the post the way it is typed. You can maintain a UOA history in a text editor like Notepad or Wordpad, then simply paste the text into the code window. To post in a code window simply click on the # symbol in the full reply screen like this:
Code:
OIL             GC0w30   GC0w30
MILES IN USE    4.4k     4.6k
MILES           152.5k   148.1k
SAMPLE TAKEN    10/27/07 7/21/07
ALUMINUM        2        3
CHROMIUM        0        1
IRON            12       17
COPPER          14       13
LEAD            22       19
TIN             0        0
MOLYBDENUM      6        18
NICKEL          0        1
MANGANESE       0        0
SILVER          0        0
TITANIUM        0        0
POTASSIUM       6        10
BORON           5        12
SILICON         7        9
SODIUM          19       24
CALCIUM         1866     2013
MAGNESIUM       525      424
PHOSPHORUS      842      797
ZINC            1082     1041
BARIUM          0        0
INSOLUBLES      0.4      0.3
WATER           0        0
FLASHPOINT F   415      395
SUS VIS 210F   66.8     67.7
cSt @ 212F     12.11    12.33
Please do not post like this as it is very hard to read:
IRON 9 8
CHROMIUM 0 0
LEAD 0 0
COPPER 2 4
TIN 0 1
ALUMINUM 2 4
NICKEL 0 0
SILVER 0 0
SILICON 14 33
BORON 45 93
SODIUM 0 0
MAGNESIUM 9 13
CALCIUM 1901 2795
BARIUM 0 0
PHOSPHORUS 845 877
ZINC 920 1004
MOLY 227 48
TITANIUM 0 0
VANADIUM 0 0
POTASSIUM 0 0
FUEL <1 <1
VIS 100 7.07 10.03
WATER 0 0
COOLANT NO NO
TBN 3.78 1.86
OXID N/A 31.0
NITR N/A 30.0
or like this:
Aluminum 6/ 3/3/3/2/2/3/2/3
Chromium 1/ 1/1/1/1/1/1/1/1
Iron 32/ 26/19/20/10/12/31/9/16
Copper 22/ 32/25/42/44/56/63/52/118
Lead 10/ 9/7/10/5/5/6/4/8
Tin 1/ 2/0/2/1/3/6/3/3
Molybdenum 6/ 7/5/11/10/60/74/65/68
Nickel 1/ 1/1/1/0/1/1/0/1
Manganese 2/ 1/1/1/1/1/1/1/0
Potassium 2/ 0/1/3/3/3/2/2/0
Boron 2/ 0/3/10/17/140/152/119/157
Silicon 10/ 9/8/10/10/12/23/37/14
Sodium 2/ 3/2/3/3/6/6/2/9
Thanks,
Wayne
Posted by: 21Rouge
Re: How to post used oil analysis results - 01/30/11 12:52 PM
Originally Posted By: wwillson
All,
For sure Wayne. And as been suggested in the past it would be very convenient if bobistheoilguy.com would upgrade and host such jpegs (as do many other forums) which would ensure the future integrity of these important links.
Posted by: Andrew MKZ
Re: How to post used oil analysis results - 01/30/11 01:01 PM
Thanks for posting. This will sure help members on this site, and the information will always be here.
Posted by: Steve S
Re: How to post used oil analysis results - 01/30/11 03:05 PM
Is there any way to make a pre set form where all we do is plug in the numbers? then all the uoas will have the same format?
Posted by: wwillson
Re: How to post used oil analysis results - 01/30/11 05:30 PM
Funny you should ask this question now. We are thinking the same thing and looking for a developer who could build the application.
Wayne
Posted by: gathermewool
Re: How to post used oil analysis results - 02/01/11 06:31 PM
Is there an easy way to post code? I copied and pasted and tried lining everything up, but half an hour later I'm still not finished inputing only 5 UOA. I gave up when the lines were jumping and not lining up. I'm sticking with posting pics unless you guys can find an easier way...
Posted by: Bill in Utah
Re: How to post used oil analysis results - 02/01/11 11:42 PM
Its not that hard. I just copied and pasted the example of what not to do in Wayne's example here;
Code:
IRON        9 8
CHROMIUM    0 0
LEAD        0 0
COPPER      2 4
TIN         0 1
ALUMINUM    2 4
NICKEL      0 0
SILVER      0 0
SILICON    14 33
BORON      45 93
SODIUM      0 0
MAGNESIUM   9 13
CALCIUM  1901 2795
BARIUM      0 0
PHOS      845 877
ZINC      920 1004
MOLY      227 48
TITANIUM    0 0
VANADIUM    0 0
POTASSIUM   0 0
FUEL       <1 <1
VIS 100  7.07 10.03
WATER       0 0
COOLANT    NO NO
TBN      3.78 1.86
OXID      N/A 31.0
NITR      N/A 30.0
Took me exactly 2 mins to format.
Try it in the test forum.
Bill
PS: Send me what you have in a PM and I'll line it up and send it back to you so you can see what it looks like!
Posted by: labman
77 Chevy LUV, 1.8 L 4, Mobil 1 5W-30 - 04/19/11 08:56 PM
I was late sending it in, but here is the report for the one year run of my truck. It doesn't see a lot of miles. I have a few more months to go on my first year run on my Cavalier.
MAKE/MODEL: Isuzu 1.8l
OIL TYPE & GRADE: Mobil 1 5W/30 FUEL:Gasoline(Unleaded) OIL USE INTERVAL:2,000 Miles
Thanks for the note. This is a gas engine, and that changes a lot. Your wear numbers have
increased since last sample, but they're still normal for this type of Isuzu gas engine (compare to averages, which are based on 4,700 miles on the oil). The fuel % we calculated last time was also wrong. If you'd been using a diesel oil it would have been 4.0%, but with a gas oil it was just a trace. (We calculate fuel off the flashpoint, and the "should be" flash for a gas oil is different than a diesel oil.) Note silicon--a sealer/lube? If not, check the air filter. The TBN is strong at 5.7.
Code:
Sample Date  12/15/09
Make Up Oil    1 qt
ALUMINUM        4
CHROMIUM        2
IRON           17
COPPER          7
LEAD           15
TIN             2
MOLYBDENUM    103
NICKEL          1
MANGANESE       0
SILVER          0
TITANIUM        0
POTASSIUM       3
BORON         105
SILICON        90
SODIUM          8
CALCIUM      2483
MAGNESIUM      14
PHOSPHORUS    714
ZINC          800
BARIUM          0
                             Values Should Be*
SUS Viscosity @ 210F  55.3          55-62
cSt Viscosity @ 100C   8.86      8.8-11.1
Flashpoint in F      330           >365
Fuel %                  1.5         <2.0
Antifreeze %            0.0          0.0
Water %                 0.0          0.0
Insolubles %            0.3         <0.6
TBN                     5.7
Posted by: Bruce T
Re: 77 Chevy LUV, 1.8 L 4, Mobil 1 5W-30 - 04/22/11 12:32 PM
Hosting jpg files or developing an automated application would be helpful,
although it would require additional disk space and money to make it work.
Yes! The code block method has been improved! I tried it in the Test Forum.
The spaces between columns used to disappear when you posted and ruined
the column alignment. Now, every space I typed in the post was saved.
Posted by: swingwing
Re: 77 Chevy LUV, 1.8 L 4, Mobil 1 5W-30 - 05/29/11 08:38 AM
Having trouble formatting (Test Forum). I click on the # sign and paste my data. Everything looks great until I click on Preview Post, then columns collapse. Suggestions on what I'm missing. Car in Test forum is 2002 BMW M5.
Posted by: Bruce T
Re: 77 Chevy LUV, 1.8 L 4, Mobil 1 5W-30 - 06/14/11 02:59 PM
Swingwing, it is a little tricky to put your UOA in a code block. Copy and paste the text from another document. You can always manually type the text, but then you have no permanent copy saved on your computer.
If necessary, correct any issues with the column spacing. When you're ready, click and drag your mouse to highlight your UOA, click the # button, four choices will drop down, click on the fourth option. It will add the commands to start and end the code block. When you click on "Preview Post," the UOA should be in a code block.
I usually manually type the commands to start and end the code block, but I can't repeat the full commands here or I will unintentionally create a code block inside this reply. Aaargh!
Posted by: Bruce T
Re: 77 Chevy LUV, 1.8 L 4, Mobil 1 5W-30 - 06/14/11 03:20 PM
Sorry, swingwing, I just found the UOA where you had already figured this out:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2274025&page=all
Posted by: Alamogunr
Re: How to post used oil analysis results - 11/17/11 05:14 PM
I'm trying to follow the directions to post a UOA. I must be dense. I can't find a # sign on the full reply screen to post code so the numbers remain lined up in the post. HELP!
John
W.TN
Posted by: Quattro Pete
Re: How to post used oil analysis results - 11/17/11 07:18 PM
Just type [code] before the text you want to show as coded...
...and then [/code] after it.
Re: How to post used oil analysis results - 11/17/11 08:07 PM
Thanks. I really am dense.
Posted by: SubLGT
Re: How to post used oil analysis results - 11/25/11 10:11 PM
....................We prefer that you use a code block because the text remains aligned in the post the way it is typed. You can maintain a UOA history in a text editor .................... then simply paste the text into the code window. To post in a code window simply click on the # symbol.............
Tried the above, did not work for me. Had my (Macintosh) text document perfectly aligned with my headings and data, all in columns on left tabs. The tabs get lost/jumbled when the document is pasted into the code window. The data columns lose their alignment. shrug
Posted by: teddyboy
Re: How to post used oil analysis results - 02/14/12 05:16 PM
I am more dense. When I hit the # sign and select the code box, I get two boxes with the word code. Where I go from there, I haven't a clue. When I try to copy out of the Blackstone pdf, I am unable to highlight any of the text to copy. Any help would be greatly appreciated, but you need to realize that I have almost no skill here.
Re: How to post used oil analysis results - 02/14/12 05:50 PM
They you type everything you want to type between these two code tags. That's all there's to it.
There is no easy way to copy out of the Blackstone pdf. You need to type it all up by hand.
What was suggested previously was to copy text from another person's UOA that's already been posted here, like the one at the top of this thread. This will save you the effort of having to type all the element names from scratch. You will still need to replace the actual values though next to each element with your own from your own UOA report.
Posted by: teddyboy
Re: How to post used oil analysis results - 02/14/12 06:24 PM
Thanks for the reply; I still couldn't make it work so just did the best I could.
Re: How to post used oil analysis results - 02/14/12 06:31 PM
You mixed up the parenthesis.
Posted by: teddyboy
Re: How to post used oil analysis results - 02/14/12 06:39 PM
I wish I knew what that means.
You must think I'm the dumbest person on the planet. Would it help to know that I have a Ph.D. in economics? Or would that just exacerbate your low opinion? In any event, I really do appreciate your trying. Maybe I'll be more patient when my students can't understand linear regression
Posted by: teddyboy
Re: How to post used oil analysis results - 02/14/12 10:47 PM
It's a miracle, I figured it out. The copied material goes between the two parentheses. Check out what I did in the test forum.
Re: How to post used oil analysis results - 02/15/12 08:19 AM
Yes. Sorry I wasn't clear on that. Glad you got it working.
Posted by: teddyboy
Re: How to post used oil analysis results - 02/15/12 11:47 AM
No apology necessary; the problem was on the receiving end but I did eventually figure it out. Thanks again.
Posted by: 21Rouge
Re: How to post used oil analysis results - 02/16/12 08:26 AM
BITOG is the only forum I frequent which does not provide storage for uploaded files i.e. jpgs.
Posted by: motor_oil_madman
Re: How to post used oil analysis results - 03/14/12 11:00 AM
I'm pretty sure the guy wants info on his uoa and not a lecture on how to post it.
Posted by: 21Rouge
Re: How to post used oil analysis results - 03/15/12 08:55 AM
The title of this thread being "How to post used oil analysis results".
Posted by: Sam_Julier
Re: How to post used oil analysis results - 06/20/12 08:13 AM
It would be extremely helpful to be able to upload the PDF of the Blackstone UOA. Could someone list the steps for this please? Thank you.
Posted by: jkhawaii
Re: How to post used oil analysis results - 06/24/12 01:06 AM
posting the UOA using the method not recommended is the only way I know how.
Re: How to post used oil analysis results - 07/24/12 10:58 AM
wwilson: I am new to BITOG and find the lack of a pre-set form or simple PDF upload option a drawback. I hope it will receive consideration. I'd be happy to make a donation to that end. Otherwise I have learned an immense amount about oil and maintenance.
Posted by: atc250r
Re: How to post used oil analysis results - 01/04/13 07:26 PM
Not only is it very difficult to post a UOA on this forum, it is nearly impossible for a person to post pictures. Every other forum I frequent is very user-friendly for posting pics. NOT BITOG!!!
Posted by: sir1900
Re: How to post used oil analysis results - 01/04/13 08:12 PM
Go to a thread with an image of a UOA. Click on "Quote" and you will be able to see the html coding used to post a picture.
Posted by: 74DartSport
Re: How to post used oil analysis results - 03/06/14 08:33 PM
Code:
MI on Oil			7,823
MI on Unit 			178,283
Sample Date			03/02/14
Make Up Oil Added		6 quarts
Oil Type		WM Super Tech High Mileage 10W40
				Universal Avgs
ALUMINUM		7		3
CHROMIUM		1		1
IRON			2	15
COPPER			4		14
LEAD			0		0
TIN			0		1
MOLYBDENUM		30		72
NICKEL			1		0
MANGANESE		1		2
SILVER			0		0
TITANIUM		0		0
POTASSIUM		2		1
BORON			14		59
SILICON			6		10
SODIUM			322		38
CALCIUM			2045		2157
MAGNESIUM		11		72
PHOSPHORUS		847		673
ZINC			924		788
BARIUM			0		0
SUS Viscosity @ 210F	66.7
cSt Viscosity @ 100C	12.06
Flashpoint in F	405
Fuel %			<0.5
Antifreeze %		?
Water %			0.0
Insolubles		0.2
TBN			2.8
Posted by: Eddie
Re: How to post used oil analysis results - 09/12/14 08:26 PM
I just gave up posting a UOA. Let us know when a Cut & Paste function is available. ed
Posted by: vintageant
Re: How to post used oil analysis results - 09/18/14 10:19 AM
Ditto what Eddie wrote.
C'mon guys! It's almost 2015!
Posted by: dmk
Re: How to post used oil analysis results - 12/10/14 11:26 PM
I agree. Using host sites this code stuff is [censored].
Posted by: aa1986
Re: How to post used oil analysis results - 12/10/14 11:32 PM
Sorry but "nearly impossible" is quite an exaggeration.
And the reason for putting the results in a code box is to avoid having situations where the picture disappears from the hosting site and the UOA is no longer available.
Posted by: Al
Re: How to post used oil analysis results - 12/11/14 09:46 AM
How do I post the blackstone pdf??
Re: How to post used oil analysis results - 12/13/14 09:24 AM
Member Robertcope used to have a great converter used on this site.
If he could be persuaded to get it working again, it would surely benefit many!
Posted by: Saul
Re: How to post used oil analysis results - 03/16/15 07:12 PM
This is incredibly hard to upload. I cant even image host it properly. Spent hours trying to upload my analysis....
Posted by: SJohnson
Re: How to post used oil analysis results - 03/16/15 08:54 PM
Find someone under a the age of 30 to help you. That's what I do.
Posted by: Nitronoise
Re: How to post used oil analysis results - 01/20/16 02:16 PM
is there a way just to scan it or save it as a PDF then paste it into the box ??
Posted by: Garak
Re: How to post used oil analysis results - 01/20/16 11:24 PM
No, it has to be hosted somewhere else, or the text entered into the post itself.
Posted by: revvedup
Re: How to post used oil analysis results - 03/26/16 12:10 AM
This is a real interesting site, and the info about oil analysis is interesting. What I would really like to find out is where the actual real info for actually getting an oil analysis done. Like price and how to request it.
Posted by: Clarkbug
Re: How to post used oil analysis results - 03/29/16 11:11 AM
Here you go!
http://www.blackstone-labs.com/free-test-kits.php
Request a free test kit, then mail it in and pay $28 to get the results.
