Oil analysis on new PSD
s. tx
Alum 6
Chrom 4
Cop 18
iron 15
lead 5
tin 4
silcon 41
pots 13
sod 7
water oxd visco 13.6
gly none detc.
TBN 9.8
SAE 43
Soot
Motor has 15,000
Oil had 10k.
Changed Full flow at half way, added 3qts.
Oil guard by-pass.
Shell rot 15-40
Did full change when sample was taken. Trying Shell Rot syn.
Any thoughts or input.
look up in the diesel oil analysis I posted my wifes 2002 power stroke using Shell "syn" 5w/40 not much difference. To get real good numbers a cummins engine is needed.
here is some info on psd oil analysis' http://members.aol.com/fmtrvt/OilStudy/current.pdf I don't think there is much difference in the oils .
[ June 04, 2003, 04:33 PM: Message edited by: Steve S ]
Can anyone explain why the silicon level is so high? Is that due to break in? Otherwise it would indicate some sort of leak in the air intake or a really dirty filter...
Lightman,
The PSD uses a silicone type oil pan gasket, which tends to leach for the first 20k miles or so. These levels are perfectly normal and I see it all the time with this engine.
TS
