2012 Ram 3500 6.7 Cummins
Posted by: hollnagelc
2012 Ram 3500 6.7 Cummins - 05/24/13 10:23 PM
First sample I have ever had done. Thought I would share. This is the second oil change for the truck. Oil used is Valvoline Premium Blue 15W/40
Posted by: LargeCarManX2
Re: 2012 Ram 3500 6.7 Cummins - 05/24/13 10:45 PM
Excellent, bump her OCI up to 7.5K and resample.
Posted by: Donald
Re: 2012 Ram 3500 6.7 Cummins - 05/25/13 06:21 AM
I usually wait until an OCI that starts after 20K to do a UOA. Before then it could be anything.
I prefer UOAs that provide oxidation and nitration.
Thanks for sharing.
Posted by: dnewton3
Re: 2012 Ram 3500 6.7 Cummins - 05/26/13 01:53 PM
There is nothing but break-in wear here; this is not data that can be used to establish any range or trend.
On the positive side, contaminants look well in control.
I would OCI at 10k miles and again at 15k miles. The goal would be to flush out the break-in metals. Don't even both with a UOA for these next few OCIs; waste of money.
Stick with the VPB; excellent product and reduces variables for future UOA trending.
At 15k miles, start doing 7.5k mile OCIs, and then start your UOA data tracking.
Re: 2012 Ram 3500 6.7 Cummins - 05/26/13 01:56 PM
Thanks for the advice guys!
Re: 2012 Ram 3500 6.7 Cummins - 07/29/13 05:58 PM
Here is the run with the premium blue extreme 5w40 6000 miles.
Posted by: skyactiv
Re: 2012 Ram 3500 6.7 Cummins - 07/30/13 06:13 AM
I'm a journeyman diesel mechanic at UPS. The yard shifter trucks use a de-tuned version of the 5.9 or 6.7 Cummings depending on the year. Those engines can last seemingly forever. Keep in mind if you ever have a fuel system issue, don't drive it and get it fixed. Cylinder wash down is the only thing that has ruined these engines in our industrial application.
Re: 2012 Ram 3500 6.7 Cummins - 07/30/13 09:01 AM
That's great to hear. My main concern with the 6.7 cummins was possible fuel dillution. From the regen process. But I think with my driving routine it's not going to be an issue (knock on wood).
Re: 2012 Ram 3500 6.7 Cummins - 10/27/13 10:12 AM
Here is the latest on the vpbe. Used up what I had I have delo 400 le 15w40 in the truck now. 11.50 a gallon is nicer than. 26.00 a gallon.
Posted by: dustyroads
Re: 2012 Ram 3500 6.7 Cummins - 10/27/13 02:24 PM
Thanks for sharing your reports!
I've never tested any of my diesels that low in mileage so I don't know if that aluminum number is normal at that stage or not (referring to the latest report). It looks like the engine is coming along nicely, though.
I don't blame you for saving money with delo 400. It'll do very well for you.
Posted by: jayg
Re: 2012 Ram 3500 6.7 Cummins - 10/28/13 03:25 PM
x2
Re: 2012 Ram 3500 6.7 Cummins - 10/28/13 04:59 PM
Yeah that's the plan. Trying to get off the synthetic kick. It was real popular when I first started buying vehicles. Got drawed into it and just now trying to not waste money. hooked
Re: 2012 Ram 3500 6.7 Cummins - 12/29/13 10:15 AM
Here is a short run of the delo. Went ahead and changed early. Recently made some modifications on the truck. So I wanted to drain this and see how the next one looks. Also put a fumoto valve on this time so maybe my sample taking will be a cleaner experience smile
Re: 2012 Ram 3500 6.7 Cummins - 12/29/13 04:40 PM
I'm a bit worried about that aluminum number. It's not coming down as the engine is breaking in, although 21k is nowhere near "broke in". I've never watched a diesel breaking in as you are showing, so maybe there's nothing wrong.
With the increased aluminum in this last short interval it just seems that something is wrong, but I have a lot to learn.
Re: 2012 Ram 3500 6.7 Cummins - 12/29/13 04:43 PM
Yeah I guess I'll see how it goes on the next one. I did have more idle time (cold mornings) and short distance drives during this interval.
Re: 2012 Ram 3500 6.7 Cummins - 02/13/14 05:35 PM
Valvoline premium blue did a sample 3,000 didn't drain oil. Curiosity got the best of me the reason for the early sample.
Re: 2012 Ram 3500 6.7 Cummins - 02/14/14 06:09 PM
I know it's only 3,000 miles but I think it's looking good. The aluminum was concerning in your previous reports but I'm thinking it's going to be just fine from here on out.
This is just plain ol' premium blue? Looks like your Cummins may really like it. Cummins and Valvoline do collaberate so I guess it makes sense.
Any idea how many miles for the universal averages?
Re: 2012 Ram 3500 6.7 Cummins - 02/14/14 07:37 PM
They said universal is 6,300 miles.
Posted by: A_Harman
Re: 2012 Ram 3500 6.7 Cummins - 02/20/14 03:20 PM
Let me guess; the oil samples at 12450 and 18069 miles were on Delo, and the rest were on VPB?
With every oil change, the iron has been trending down in terms of ppm per 1000 miles. I think your engine is still in the process of breaking in.
It's interesting to see Titanium in VPB.
Re: 2012 Ram 3500 6.7 Cummins - 02/20/14 07:30 PM
Those oci were vpb 5w/40. I guess they only add the titanium to the 15w/40. Both the uoa with it had the titanium.
Posted by: A_Harman
Re: 2012 Ram 3500 6.7 Cummins - 02/21/14 07:39 AM
Wow. I'm surprised to see such different additive packages in two oils that are both called "Premium Blue".
And then the oil sample at 21718 miles was Delo?
Re: 2012 Ram 3500 6.7 Cummins - 02/21/14 08:33 AM
Yes that was the only one done with delo.
Re: 2012 Ram 3500 6.7 Cummins - 03/29/14 09:45 PM
Valvoline Premium Blue 15W/40. I did change at this interval.
Posted by: dnewton3
Re: 2012 Ram 3500 6.7 Cummins - 03/30/14 07:10 PM
Not really sure what's driving your OCI decision, but you could get a lot more value out of the lube ... This fluid was changed way too early.
Re: 2012 Ram 3500 6.7 Cummins - 03/31/14 05:00 AM
Yeah I should of just sampled and kept going. I didn't have much going on that day so I decided to change the oil and fuel filters. Having that valve now just makes it a lot nicer and easier to change the oil.
Posted by: Artem
Re: 2012 Ram 3500 6.7 Cummins - 08/09/14 02:39 PM
I purchased a new 2014 Ram 3500 HD with the Aisin tranny and couldn't decide what oil to use, so this thread has pointed me towards Valvoline as a good choice but first I want to see how Shell's Rotella will handle the Cummins block. It's easy to get an is always available at rollback prices from Wally World.
Thanks OP. I say you start extending your oil change intervals a bit further. You're definitely dumping it too early. My manual says to change every 15k miles!!!
Posted by: SilverC6
Re: 2012 Ram 3500 6.7 Cummins - 08/09/14 08:51 PM
Rotella is an excellent choice for the Cummins.
T3 15W-40 is perfect in sunny FL.
You should get 800,000 miles out of that engine/tranmission combination.
My 2013 manual says 15,000 miles, every 6 months, or when the light comes on.
Posted by: Artem
Re: 2012 Ram 3500 6.7 Cummins - 08/14/14 07:38 PM
800k with what type of driving? Mine will be used exclusively for work and will constantly be towing 10-25,000 pounds of... Whatever.
I hope to get a million outta the power unit before a serious rebuild is needed, so we'll see how she holds up.
Posted by: SilverC6
Re: 2012 Ram 3500 6.7 Cummins - 08/17/14 10:37 PM
I'm with you.
Let's shoot for 1,000,000 miles.
Re: 2012 Ram 3500 6.7 Cummins - 08/20/14 10:25 AM
Count me in on the million mile challenge smile. It'll take me forever to get there though lol. Only avg about 30,000 miles a year.
I know of a guy with over 570,000 on a 2011. And still going.
