1997 Toyota Camry Timing belt
Posted by: Nick1994
1997 Toyota Camry Timing belt - 11/22/13 11:06 PM
I'm buying a 1997 Camry 2.2L automatic tomorrow and will change the timing belt immediately. A Toyota dealer in town has a service coupon for $229.99 to change it, what's the catch? Is it a good deal?
Here's the link to the dealer special:
http://riverviewtoyota.com/Service-Specials/
Posted by: cmorr
Re: 1997 Toyota Camry Timing belt - 11/22/13 11:20 PM
Other parts are usually replaced as well (tensioner, water pump,etc) whatever is specific to that model
Posted by: Chris142
Re: 1997 Toyota Camry Timing belt - 11/22/13 11:59 PM
Does it need the timing belt now?
Posted by: Nick1994
Re: 1997 Toyota Camry Timing belt - 11/23/13 12:11 AM
Previous owner has had it for 85k miles and hasn't changed it, it has 185k now. Who knows what the person before him did.
Posted by: The Critic
Re: 1997 Toyota Camry Timing belt - 11/23/13 12:17 AM
It probably needs drive belts, seals, water pump and tensioner at that mileage.
Posted by: crazyoildude
Re: 1997 Toyota Camry Timing belt - 11/23/13 01:21 AM
Be careful with car stealers they may advertise $225.00 but when they open it up and they tell you it needs one of these and 2 of those and..... your bill will go way up. most of them are not so honest as we all know.
Re: 1997 Toyota Camry Timing belt - 11/23/13 02:14 AM
Sure, telling customers what their car really needs is a dishonest practice?
The coupon clearly states to see the dealer for other important details; anyone who is remotely familiar with a timing belt system will know that a complete service will often require more than just the belt. And don't tell me that this is a bait and switch -- if you are not an educated consumer, that's your own darn fault.
You have a serious, unwarranted bias against dealerships. What makes independent shops so great anyway? They lack the continual factory training, availability of tech line for assistance and are unable to provide the service experience that most discerning clients expect. The dealership is almost always the most consistent, safest choice for a quality repair using the proper parts.
Posted by: Barkleymut
Re: 1997 Toyota Camry Timing belt - 11/23/13 03:57 AM
Critic - I rarely do this, but wow that is one heck of a good post. Especially the part about being an educated consumer.
If I wanted to buy a fancy $1,000 watch tomorrow, then I would call up one of my buddies that might know a thing or two about watches...because I know NOTHING about them, except that they tell time. Likewise if one of them called me up and said why is my car making this noise, I would tell them to bring it over. It is not anyones (dealers) fault if a consumer doesn't know anything about cars and "feels misled" or "ripped off".
Posted by: Turk
Re: 1997 Toyota Camry Timing belt - 11/23/13 05:41 AM
My Wife drives the same car, same engine with 200k on the clock. Yea, time to change it, it won't break tomorrow, but it's time anyway.
Posted by: cjcride
Re: 1997 Toyota Camry Timing belt - 11/23/13 06:08 AM
Probably sold it rather than do the belt. Most likely original belt in there.
Posted by: simple_gifts
Re: 1997 Toyota Camry Timing belt - 11/23/13 07:23 AM
+1 for The Critic; Dealership did the TB on my friends V8 Tundra for much less than an independent shop. With an engine with so little production @ the time, I didn't want someone with little or no documentation/experience "in there"
Posted by: BISCUT
Re: 1997 Toyota Camry Timing belt - 11/23/13 07:26 AM
Belt itself isn't difficult at all. BUT I would seals and pump if it was never done before. Add the belts as well. Careful with the PWR Str belt, mine always seems to slip a bit and loosen on me.
If I just got mine at 185k I would do plugs, wires, cap, fuel filter, PCV and then the timing belt and other belts with seals and pump also. These aren't expensive or difficult. End it with a radiator drain refill (distilled water of course) and ride her for a while.
I would keep a valve cover gasket handy (cheap) as they are know to leak out after a while. Easiest gasket ever to fix!!
Posted by: edwardh1
Re: 1997 Toyota Camry Timing belt - 11/23/13 07:45 AM
agree do it all at once
Posted by: stro_cruiser
Re: 1997 Toyota Camry Timing belt - 11/23/13 07:46 AM
While you in there and have it all apart, Definately replace all of the oil seals that are right there!
Posted by: Maximus1966
Re: 1997 Toyota Camry Timing belt - 11/23/13 08:03 AM
...The dealership is almost always the most consistent, safest choice for a quality repair using the proper parts...
LOL!
Posted by: The_Eric
Re: 1997 Toyota Camry Timing belt - 11/23/13 08:58 AM
I definitely agree with the first part of your post. It can be pretty frustrating when you tell a customer they need additional work and they look at you with distrust... Like you're trying to rip them off. I suppose being a mechanic is a bit like being a lawyer. Many people never completely trust them and only go when they're in hot water, then complain when they're through...
The second part, I'm not completely in agreement with. The continual lack of factory training to me really only comes in on the newest cars. Good indy shops undergo schooling or look for other ways to stay current on their knowledge. They also have tech resources available to them, including factory hotlines or factory trained hotlines in many cases. All they have to do is pay. The bottom line is, while a dealer can be a safe bet in many cases, good workmanship follows the mechanic, not the name on the building.
Re: 1997 Toyota Camry Timing belt - 11/23/13 09:10 AM
Some of the people they have working at the stealers are not so great by any means thats for sure
Posted by: bullwinkle
Re: 1997 Toyota Camry Timing belt - 11/23/13 09:21 AM
Some dealers are OK: others, not so much. What would make me a little nervous is their need to ADVERTISE their service prices...
Re: 1997 Toyota Camry Timing belt - 11/23/13 09:23 AM
When the stealers advertise $200.00 and then there is all the "extras" they "forgot" to mention that brings the grand total up to a whopping $500.00 dollars yes that is dishonest and very stealer like. Some of them are forced to be a little more honest because word travels fast these days and they have very little non warranty business. Now there are exceptions to every rule there are some that a good and honest but on the average everyone knows....
Posted by: hypervish
Re: 1997 Toyota Camry Timing belt - 11/23/13 09:29 AM
Some of the people they have working at the independent shops are not so great by any means thats for sure
I think he owns his own engine shop or something, if I remember correctly. He may be trying to attract more customers. lol
Posted by: diver1972
Re: 1997 Toyota Camry Timing belt - 11/24/13 12:33 AM
It seems very much in line with many ads I've seen locally over the past several years.
Originally Posted By: BISCUT
...and ride her for a while.
LOL
Well-stated. approved
Posted by: vssjim
Re: 1997 Toyota Camry Timing belt - 11/24/13 10:28 AM
when doing seals on those engines the oil pump cover o ring should be changed as they leak alot on older engines. I don't see anybody being able to do a toyota 2.2 t belt job with drive belts water pump and three seals and oil pump cover and new coolant for five hundred dollars unless labor is free almost. We use Goodyear belts, Aisin water pumps, Beck Arnley toyota coolant and Fel Pro seals and oring We have done many of these over the years and the 225.00 is to take off old t belt replace with new T belt only and re use everything else which on a 185,000 mile car is not a real good idea.
Posted by: zzyzzx
Re: 1997 Toyota Camry Timing belt - 11/25/13 10:05 AM
The catch is that's only for the belt and if you want the water pump, or any idlers replaced, those are extra, and most likely a lot extra. Call them to find out what's included and post that back here.
Posted by: Hokiefyd
Re: 1997 Toyota Camry Timing belt - 11/25/13 10:26 AM
Consider doing the job yourself. I changed the belt on our Acura MDX earlier this year and it was a very enjoyable job. A 4-cylinder Camry has got to be even easier. I saved well over $500, and was able to verify the quality of the parts going on it (I used OEM Honda parts).
Posted by: Nick1994
Re: 1997 Toyota Camry Timing belt - 11/25/13 10:47 AM
I called and they said its $229 to replace the timing belt. If I want new tensioners or a drive belt it's just the cost of parts, no added labor. If I want a water pump I have to pay extra for labor and for the parts for it.
Posted by: dishdude
Re: 1997 Toyota Camry Timing belt - 11/25/13 11:55 AM
Sounds pretty reasonable!
Posted by: zzyzzx
Re: 1997 Toyota Camry Timing belt - 11/26/13 09:57 AM
Yes, but they didn't tell you that that they will be charging you around $??? for a timing belt tensioner that you can get off Rock Auto for $35 (used 2000 Camry and gates tensioner pricing). That's assuming that they actually replace it since they can always say that they did and charge you anyway.
What's a Reasonable Cost for Timing Belt Replacement?
http://www.toyotanation.com/forum/155-2n...eplacement.html
Posted by: hattaresguy
Re: 1997 Toyota Camry Timing belt - 11/26/13 01:59 PM
Just do it yourself, I did a timing belt job about a decade ago on a 1993 Camry and I don't remember it being very challenging.
Posted by: Scout1
Re: 1997 Toyota Camry Timing belt - 11/26/13 09:33 PM
The shop part of a car dealership is ultimately under the same management as the car sales and faces similar revenue and profitability targets. Has ANYONE ever found an honest car salesman??? I'm sure they exist, but the other kind are far more prevalent.
Two reasons to stay away from dealerships in my mind; first is the markup. OEM parts are a lot more expensive than aftermarket. Second is the pressure on the service writers and mechanics to drum up extra business. I don't know for sure but I sure suspect they will even go so far as break something to sell you a fix. Case in point, I took my Chrysler minivan to the dealer for a transmission service since it seemed like a reasonable price. they called me back saying someone had over tightened the pipe to the transmission cooler and a new one was $175 since the whole pipe needed to be replace. They showed me a drippy fitting into the radiator. Nope, it'll be fine I told them and besides, they were the only ones who had touched that pipe before during a prior tranny fluid change. I snugged the fitting down when I got home. No leak! I rest my case...
