Another take on lifetime fluid - BMW ZF
Posted by: CBR.worm
Another take on lifetime fluid - BMW ZF - 04/18/14 01:31 PM
First of all, I am not a believer in lifetime fluid.
We have an '08 E60 BMW W/ the ZF 6hp19(or 24?). The car has about 70k on it, I asked our dealer about a ATF change, they said it would be $1,000 and would void our warranty, but that they would do it if we really wanted to.
He explained that the fluid is a lifetime fluid, etc. I said that I did not believe in lifetime fluids and could not see any reason not to change it. He said that the fluid properties change as it ages and that the TCM compensates for these changes. He said that if you replace the fluid you have to do one of two things. One is tell the TCM to forget all learned value, the other is not do anything relative to the TCM.
He said that there are three very common failure modes for these transmissions, which is why Audi extended the warranty coverage on their vehicles with this ZF tranny.
The first is the mechatronic sleeve leaking, causing a low fluid condition and mass destruction (easy fix if caught early). The second is the mechatronic assembly (valvebody) solenoid failure, causing mass destruction in an instant with no prior signs, the third is replacing fluid and having the parameters be out of line enough that mass destruction ensues within a few thousand miles - in some cases after deleting learned values the transmission will slip and cook itself post haste.
he said the only solution is to change the fluid very regularly, or never at all.
Does anyone think there is any validity to this crazy claim of the tranny adjusting to the degrading fluid and being destroyed if new fluid is put in place? kind of a different take on the old don't ever change a high mileage ATF (which in my mind 70k is not high miles).
My inclination is to do it myself given the price, but these are kind of a pain to do. I just wanted to see if there is any validity to their claims. The tech I talked to seemed to be pretty on top of things.
Posted by: The Critic
Re: Another take on lifetime fluid - BMW ZF - 04/18/14 01:46 PM
I thought BMW recently revised the interval to 100k for ATF. I've seem a couple of E90s with this recommendation. Are you sure that yours doesn't have the 100k recommendation in the manual?
With that said, in light duty use, I've seen a lot of cars go 150k+ on the original oil fill with no problems. Tranny failures due to oil issues are rarely proven and are not nearly as rampant as the people on this forum would like you to believe.
Posted by: DirkDiggler
Re: Another take on lifetime fluid - BMW ZF - 04/18/14 01:53 PM
I was told same thing on our X5. It was a CPO that had approx 60k on it when bought dec 2010. I went to dealer @ 70k to have fluid changed and they wanted $900 and said it would fail. I used "bimmer shops" search enginge, found an awesome indy, and for $300, I got all of the fluid and new filter (the entire pan is a filter). I had it done again around 110k and have it on a 30-40k change process.
Posted by: drtyler
Re: Another take on lifetime fluid - BMW ZF - 04/18/14 01:58 PM
Here is a document from ZF that states a change interval between 80,000 and 120,000 km.
Document from ZF
After reading this, I don't see anything about resetting the computer.
Posted by: Miller88
Re: Another take on lifetime fluid - BMW ZF - 04/18/14 02:13 PM
$1000 for transmission fluid change?
WOW! Guess I'm lucky with $12/gallon DexIII!
Posted by: threeputtpar
Re: Another take on lifetime fluid - BMW ZF - 04/18/14 02:49 PM
I'd suggest that you find another dealer that actually knows what they are talking about.
I didn't see if you were still under CPO warranty, but if you are just use the fluid that dealer stocks or Lifeguard 6 from ZF. I think Pentosin also makes a fluid for the 6HP trans. IIRC, it's actually blue in color for leak detection and aftermarket non-spec fluid identification.
If you're not under warranty, there are other fluids that are less expensive and suitable for the trans.
Posted by: dparm
Re: Another take on lifetime fluid - BMW ZF - 04/18/14 03:36 PM
Talk directly to the techs for the info you need. The service advisors are just glorified salespeople.
Posted by: Ram01
Re: Another take on lifetime fluid - BMW ZF - 04/18/14 06:05 PM
Wow BMW is nuts 1000$ , fresh fluid is always the best
Posted by: Wilhelm_D
Re: Another take on lifetime fluid - BMW ZF - 04/18/14 07:07 PM
Document from ZF
Yes, but be sure to use ZF LifeGuard Fluid, which retails for $14 - $21 a liter, which ZF assures us they manufacture.
On a more realistic note:
Changing the Fluid and Filter on a ZF 5HP
Posted by: CBR.worm
Re: Another take on lifetime fluid - BMW ZF - 04/18/14 08:32 PM
Yeah, I figured it was a bunch of [censored]. I was surprised that they said they would void the warranty if I paid them do it.
The vehicle in question is a CPO. Actually the CPO warranty is about to expire, so I am not to concerned about the warranty, but the tech made me nervous for sure. Maybe the techs get commission for selling new cars as well...
That document is great. I planned to order the LifeGuard 6 and do it myself. I was surprised to see that the pan/filter is plastic.
Posted by: drtyler
Re: Another take on lifetime fluid - BMW ZF - 04/22/14 05:45 PM
Here's a bit more.
Letter from ZF
Good luck with the change. There are quite a few DIYs for this job on the web. Here's one from BavAuto:
BavAuto Link
Posted by: BSchmidt25
Re: Another take on lifetime fluid - BMW ZF - 05/01/14 02:37 PM
BMW E60 owner here as well ('07 530xi) with the 6HP19X. I'm about to tackle this job too. This is very useful information, so thanks to those that have shared it. What are some opinions on the fluid options for this transmission? I was looking at both Redline D6 and Amsoil ATL. Consensus seems to be that the D6 is better. Is that still accurate? Any other good options?
I was considering proactively replacing the mechatronic sleeve while I'm down there. I don't have any problems with the transmission but I know of the issues with this part. Looks like it's a pretty easy job, but has anyone else done it? Tips?
Thanks in advance.
Posted by: BMWTurboDzl
Re: Another take on lifetime fluid - BMW ZF - 05/02/14 09:36 PM
I would stick with ZF LG6 as there is no compelling reason to use something else.
On a side note with regards to programming. I spoke with a ZF rep and he said it wasn't required because the mechtronics will adjust. Their own literature doesn't even mention reprogramming after an oil change.
FWIW I bought a change kit from thectsc.com and did a pan drop at 45k miles.
Posted by: hattaresguy
Re: Another take on lifetime fluid - BMW ZF - 05/03/14 04:04 PM
Sure lifetime is fine, I know of a number 200k mile 722.6's that were lifetime and maybe done once if at all and still are fine. Granted that was a very good gear box but its old technology.
I'm starting to change my thinking regarding ATF changes, I have never seen an AT fail where lack of maintenance was the only factor.
I wouldn't worry about it.
Posted by: ukmastermind
Re: Another take on lifetime fluid - BMW ZF - 05/04/14 03:10 PM
I was just talking with my friend about his E60 (528i) and how he just had the tranny replaced under warranty for abrupt shifting. The fluid was never changed and the mechaatronic devices failed twice. The fluid was never changed and it had 99k!
Posted by: Volvohead
Re: Another take on lifetime fluid - BMW ZF - 05/04/14 03:44 PM
I asked our dealer about a ATF change, they said it would be $1,000 and would void our warranty . . .
Time to find another dealer. That's Bee-S. Sounds to me like they want a tranny job just outside warranty.
Honestly, it depends on what you're after. If you want the box to last as long as the engine, at least a couple of changes along the way is usually helpful. On our old 855, we changed the ATF in the AW every 30k. At 250+k, it still shifted like brand new.
Otherwise, following the OEM recommendations should usually get you to 100k, unless you are really abusing the thing or it's a really bad design (some old FWD Ford boxes come to mind). If you flip your cars every 5 years, or before the powertrain warranty runs, then just do that.
The VAG DSGs call for 40K changes. They then upped the warranty on DSGs to 100k. VAG is now thinking about moving the fluid change to 50k, and some users have gone over 100k on the original juice, and their boxes seemed OK, at least at that time. Half the people doing DIY changes on DSGs perform no recalibration, without problems.
Most ATXes generate most of their contaminants during the first 5-7k. If you change it out then, you can usually go a good long time thereafter before the next change.
Unless it is presently acting up, you shouldn't hurt the tranny with a fluid change, especially not at that mileage. I'd be shocked if that tranny can't be re-calibrated.
