Best oil for new 17.5 HP engine?
Posted by: Volv04Life
Best oil for new 17.5 HP engine? - 02/18/14 07:04 PM
I just got a new lawn tractor at lowes. Can I run 15w-40 in it? I have a huge supply. If not what is the best oil?
Posted by: Ramblejam
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:07 PM
Yes.
Posted by: kyxtremetuber
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:08 PM
More then likely yes what brand engine
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:09 PM
Briggs
Posted by: cknight49090
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:10 PM
you could probably use it as long as its warmer weather I use 5w30 defy in my Kohler.
Posted by: lubedude13
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:11 PM
I would run 10w30 which is what kohler recommends. Briggs recommends 5w30 synthetic. I have a kohler and ran rotella 10w30 for 20 hours.....came out black and thick.
I now run Amsoil Small Engine Oil which is designed for small engines. Comes out looking a lot better than the rotella I was using.
If I was using rotella again I'd use the 5w40 full synthetic
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:13 PM
15-40 will work on a mower that won't see true cold starts I've been running 5w-40 in all my ope with great results
Posted by: simple_gifts
What does the OM indicate?
Thanks guys. Ill probly run T5
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:14 PM
OM doesnt say
Posted by: JHZR2
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:16 PM
Amsoil ACD
Briggs recommends 5w30 full synthetic which is available at tractor supply or lowes
Posted by: Oil Changer
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:18 PM
You have to know what the proper viscosity is if you want to care for the engine correctly. Somewhere in the OM it says what the proper viscosity is. Did it come with a separate engine manual? Call the place you bought it from and ask them. Then talk what brand.
Posted by: 95busa
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:19 PM
Doesn't matter
Posted by: JR
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:20 PM
Yes. 15w-40 will work great for summer use. i have used it many times. i prefer 5/10w-xx oil for cold weather starts.
Ken
Posted by: mrsilv04
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:22 PM
Great idea. Rotella and small engines go together just fine.
You don't have to spend big bucks for good protection.
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:24 PM
If you insist on rotella I'd go with T6
Posted by: Eddie
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:36 PM
MY 20 HP 2 cyl Bridges in my John Deere calls for a 10w30 oil and change it every 50 hours with the oil filter after the first change at 5 hours. I run PP 10w30.
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:41 PM
Thanks to all. Ill finger it out tomorrow while im at autozone. They didnt have the manual as it was a "demo". Idk how you lose a manual to a tractor that is still on the sales floor.
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:44 PM
look up the engine model and then do a web search; chances are, the engine manual is online.
http://www.briggsandstratton.com/us/en/support/manuals
Posted by: 901Memphis
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:46 PM
Mobil 1 10w30 is about perfect for that air cooled engine.
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:48 PM
I found the manual on the website. It says SAE 30. Who knew
Posted by: Pablo
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:53 PM
After a couple oil changes consider Amsoil ASE or ACD SAE 30.
Amsoil ASE SAE 30
Amsoil ACD SAE 30
So is 15w-40 a good sub for SAE 30?
It would probably work in the summer but the shoulder months the engine would be sluggish. Again a synthetic 15W-40 would be better than a non-syn 15W-40 (in cold)
Re: Best oil for new 17.5 HP engine? - 02/18/14 07:55 PM
Re: Best oil for new 17.5 HP engine? - 02/18/14 08:46 PM
Is 15w-40 a good sub for SAE 30?????
Posted by: thescreensavers
Sorry dude but your not going to tell how good an oil is based on a visual inspection.
Posted by: Clevy
Re: Best oil for new 17.5 HP engine? - 02/18/14 08:53 PM
Without going into a couple of paragraphs I'll condense.
K. I've got iirc 16 5.5 hp Honda powered air compressors,6 or 7 generators from 3500w to 6500w.
Every one of these machines run everyday. I've got 2 compressor motors with well over 10000 hours on them.
In warmer ambient temps I use rotella 15w-40 because I can buy 5 gallon pails which are required based on the volume of equipment.
I run everything on a 100 hour/2 week oil change interval.
Once I used a 0w-30 in a generator in the July 38c heat. In a single day the oil sump was low enough to trigger the low oil alert and shut off the generator.
I bought a pail of rotella on my way home from work that night.
Last week I tried qsud in the 5w-20 flavour since this winter has been brutally cold but I usually use 5w-30 super-tech,bought in 5 gallon pails.
In my experience fuel dilution is a real issue in every piece of equipment I own,so my 100 hour/second Saturday maintenance routine grew from the observation that more often than not the oil level got higher in a week,not less,so I dump it bi-weekly.
Compressors cost me 800 each. Due to fuel dilution I'm very confident wear increases in these small motors based on the simple splash lubrication system.
Oh,and 1/4 can liqui-moly mos2 every second oil change.
So yes. A 15w-40 hdeo is a suitable replacement for an sae 30,in most every application.
Posted by: Clevy
Re: Best oil for new 17.5 HP engine? - 02/18/14 08:55 PM
My thoughts exactly.
Re: Best oil for new 17.5 HP engine? - 02/18/14 08:56 PM
Thanks
Re: Best oil for new 17.5 HP engine? - 02/18/14 09:06 PM
I'm not saying that a visual determines anything. It does however make me feel like the rotella t look like it thickened due to high heat......that's why I recommended running t6 in it if he insisted on using rotella.
I was merely stating my experience....is that not ok?
You're not going to tell me how good an oil is based on just saying its a suitable replacement either!!!
Posted by: spasm3
Re: Best oil for new 17.5 HP engine? - 02/18/14 09:27 PM
I'm running amsoil mcf 10w 40 motorcycle oil in the Kawasaki engine.
Posted by: Boczech
Re: Best oil for new 17.5 HP engine? - 02/18/14 09:47 PM
Good oil to run !!! I picked some up last year at Napa that came out to $11.99 after the $5.00 mail in rebate.
Cheers
Bo
Posted by: Donald
Re: Best oil for new 17.5 HP engine? - 02/18/14 09:52 PM
Amsoil 4-Stroke small engine oil. The engine probably only takes a QT or so, and thus cost is not really an issue.
Re: Best oil for new 17.5 HP engine? - 02/19/14 01:37 AM
Mobil 1 10w30 has proven itself as the perfect sae 30 small engine oil by many members. You can substitute your favorite brand here but it's really the only reason 10w30 synthetic gets the sales they do since 5w30 synthetic is superior in almost any PCMO application.
Posted by: bubbatime
Re: Best oil for new 17.5 HP engine? - 02/19/14 02:38 AM
Directly from Briggs and Stratton. Their number one recommendation is 5W30 Synthetic followed by SAE30. I would myself go buy a 5 qrt jug of Mobil 1 5W30 Synthetic High Mileage oil at Wal-Mart and then have several oil changes and top off oil available.
Oil Recommendation
Synthetic 5W-30 -20 to 120 F (-30 to 40 C) provides the best protection at all temperatures as well as improved starting with less oil consumption.
SAE 30 40 F and higher (5 C and higher) is good for all purpose use above 40 F, use below 40 F will cause hard starting.
10W-30 0 to 100 F (-18 to 38 C) is better for varying temperature conditions. This grade of oil improves cold weather starting, but may increase oil consumption at 80 F(27 C) or higher.
5W-30 40 F and below (5 C and below) is recommended for winter use, and works best in cold conditions.
Type of oil to use
Use a high quality detergent oil classified "For Service SF, SG, SH, SJ" or higher.
Do not use special additives.
Choose a viscosity according to the table above.
Re: Best oil for new 17.5 HP engine? - 02/19/14 02:49 AM
The engine takes 48 ounces of oil, which is about a quart and a half.
Posted by: Oldmoparguy1
Re: Best oil for new 17.5 HP engine? - 02/19/14 02:55 AM
Volv04Life
What is the chance that you will be outside mowing when the temp is -30 or +30?? Really... All of this theoretical tooing anf froing is the downside of bitog, you already have an excellent oil for your briggs, it will be just fine. grin2
I've run just about everything in my old rider, including Aeroshell 15-50 aircraft oil, (it was free). If you want the very best oil get Amsoil 10w-30 Small Engine Oil, Rotella T6 5w-40, or M1 5w-40 turbo diesel. Otherwise use what you got. Do your first oil change at 5 hours, after that, every 25 to 50 hours. Service your air filter often, it is just as important as the oil. Enjoy your new toy. smile
Wayne
Re: Best oil for new 17.5 HP engine? - 02/19/14 05:50 AM
Volv04Life
Wayne
I like this recommendation!!!
Posted by: toneydoc
Re: Best oil for new 17.5 HP engine? - 02/19/14 06:21 AM
Kinda funny how they recommend syn 5w30 over entire temp range but they only recommend dino 5w30 for less than 45F or so. Wonder why that is?
Re: Best oil for new 17.5 HP engine? - 02/19/14 09:41 AM
I wanted to use it to plow my gigantic driveway in the winter. So there is a good chance.
Posted by: Bror Jace
Re: Best oil for new 17.5 HP engine? - 02/19/14 01:09 PM
The best oil for a new OPE engine is one you don't mind dumping after just a few hours of use. It's especially important if the engine does not have a spin-on oil filter. You need to flush out all that break-in debris.
Put in any XW30 oil, run it 2-3 hours, dump it and watch the glitter show!
After that? I'd get a 10W-30 HDEO oil for about the first year of use. If you experience consumption or run it for extended periods in severe heat, etc ... switch to a HDEO 15W-40.
Posted by: Eddie
Re: Best oil for new 17.5 HP engine? - 02/19/14 02:10 PM
The 20 HP B&S in my John Deere suggests dumping the factory fill at ~ 5 hours and refill with a 10w30 oil. At every 50 hours thereafter change the oil and spin on oil filter. I run 10w30 PP. Ed
Re: Best oil for new 17.5 HP engine? - 02/19/14 05:13 PM
"The 20 HP B&S in my John Deere suggests dumping the factory fill at ~ 5 hours and refill with a 10w30 oil. At every 50 hours thereafter change the oil and spin on oil filter."
Consider that the minimum care for engine break-in. I ran my new snowblower's engine for about 90 minutes (under load) then drained the oil and it looked like quicksilver/mercury.
http://i229.photobucket.com/albums/ee149...zps40854167.jpg
I drained it again 3-4 hours later, still a lot of visible glitter. Drained it a third time at the 16 hour mark and you could still see visible glitter in the oil.
The first oil was B&S factory fill. 2nd and 3rd fills were leftover Pennzoil HM 10w40.
I can't tell whether the original poster's engine has a spin-on filter or not. Briggs makes a lot of 17.5hp engines, some with, some without. A full-flow filter will catch a lot of the metal bits so 5 hours might be a good point for the 1st change. I wouldn't let the 2nd go the full 50 hours, though. Maybe 20-25? Then start your 50 hours or once-per-year schedule.
Posted by: knerml
Re: Best oil for new 17.5 HP engine? - 02/21/14 04:59 AM
Go to the B&S web site. You can download your engine users manual PDF based on model number.
If you bought the TB Pony, 5W30 synthetic is recommended.
Posted by: tig1
Re: Best oil for new 17.5 HP engine? - 02/21/14 08:43 PM
My 2 year old Craftsman 20HP Briggs calls for 10-30 and gets M1 10-30 and a new filter every year. No need at all for a 40wt oil in these engines.
