Acronyms used at BITOG.
Wi
Back in 6-2-2011, Char Baby was nice enough to start this list. I copied it and kept it updated with every acronym used on BITOG since then.
If the group would proofread for errors and list any I might have missed, I this this would make a good sticky.
AAP=Advance Auto Parts
ADBV=Anti Drain Back Valve
API=American Petroleum Institute
API-TC=2 cycle, air cooled engine oil specification
AZ=Auto Zone
BITOG=Bob Is The Oil Guy
BOGO=Buy One Get One Free
BP=British Petroleum
COF=Coefficient Of Friction
CP=Conoco Philips (makers of MotorCraft/Kendall/Philips66 and others)
CRD=Common Rail Diesel
Dino=Regular Motor Oil(s)
FAR= Free After Rebate
FF=First Fill
FLAPS=Favorite Local Auto Parts Store
FS=Formula Shell
Fuchs=European MFG of quality lubricants
GC=German Castrol...Castrol Syntec, It will say "Made in Germany" on the back. New name, changed to Castrol Edge
GTL=Gas-To-Liquid; a technology for converting gaseous products to fuels and lubricating base oils
HDEO=Heavy Duty Engine Oil
HDMO=Heavy Duty Motor Oil
HM/HMO=High Mileage/High Mileage Oils
HTHS=High Temperature, High Shear rate viscosity
IDR=I Don't Recall
IIRC=If I Recall/Remember Correctly
ISO=European Standards
J300=SAE engine oil viscosity classification standard
JASCO=Japanese Standards
KV=Kinematic viscosity
LOS=Lucas Oil Supplement
M1 AFE=Advanced Fuel Economy
M1 EP=Extended Performance
M1 ESP=Emission System Protection full synthetic deisel oil
M1=Mobil 1, all Mobil 1 oils are full synthetic
M5K=Mobile 5000 mile Dino oil, discontinued
MC=MotorCraft...Not Mobil Clean
MM=Maintenance Minder
MMO=Marvel Mystery Oil
MOA=Motor Oil Additive
MOFT=Minimum Oil Film Thickness
MOS2=Molybdenum Disulphide
NMMATCW3=National Marine Manufacturers Association
OBD=On-Board Diagnostics/engine codes
OCD=Obsessive Compulsive Disorder
OCI=Oil Change Interval
OCOD=Orange Can of Death
OD=Over Dose
OEM=Original Equipment Manufacturer
OLM=Oil Life Monitor
OP= Original Poster
OP=Oil Pressure
OPE=Outdoor Power Equipment
OT=Oil Temperature
OUO=Oil of Unknown Origin
PAO= Polyalphaolefin
PCMO Passenger Car Motor Oil
PO=Previous Owner
PP=Pennzoil Platinum
PU=Pennzoil Ultra
PYB=Pennzoil Yellow Bottle
QSDefy=Quaker State Defy
QSED=Quaker State Extended Durability
QSGB=Quaker State Green Bottle
QSUD=Quaker State Ultimate Durability
RL=Red Line oil
SBC=Small Block Chevy
SLOB=Street Legal Octane Booster
SOPUS which stands for Shell Oil Products United States
ST/STD= SuperTech/SuperTech Dino
STS=Super Tech Synthetic
TC=Spec for low ash 2 cycle air cooled engine oil
TCW3=Spec for no ash 2 cycle liquid cooled engine oil, W means Water cooled
UCL=Upper Cylinder Lubricant from Lucas, a gasoline additive
UOA=Used Oil Analysis
VDB=Valvoline DuraBlend
VI=Viscosity Index
VML/ML=Valvoline MaxLife/MaxLife
VOA=Virgin Oil Analysis
VSET=Valvoline Synpower Professional Engine Treatment
VSOT=Valvoline synpower oil treatment 15 oz VSOT (Valvoline Synthetic Oil Treatment)
VWB=Valvoline White Bottle
WPP=Warren Petroleum Products
XOM=Exxon Mobil
YMMV=Your Mileage May Vary
LOS= Lucas oil STABILIZER , nice list tho
Originally Posted By: volk06
CEG : Castrol edge gold
CEB : Castrol edge syntec
CEB : Castrol edge syntec? Shouldn’t this be CES
Or is this
CEB=Castrol Edge Black bottle/with Syntec
I will add the following acronyms and reformat as shown.
CEL = Check Engine Light
IDK = I Don't Know
FF = Factory Fill
lOS = Lucas Oil Stabilizer
US0 = use search option
CEG = Castrol edge gold
CEB = Castrol Edge Black bottle/with Syntec (pending approval of acronym)
AW = Anti-Wear
PC = Petro Canada
AF = Air Filter
RP = Royal Purple
If the group would proof read for errors and list any I might have missed, I this this would make a good sticky.
FF=First Fill
Dino is also sometimes called "conventional oil"
FF = .... or Factory Fill
GC = ... sometimes referred to GREEN Castrol because it originally was green.
SLOB = .... Street Legal Oil Boost (I think)
add these
BBC = Big Block Chevy
CSK = Cold Start Knock. Refers to some GM V-8 (5.3) engines made since 1999 that knock for a few seconds after a cold start. It also used to be an abreviation for a chain of auto parts stores called "Checker, Schucks, and Kragen - Now called O'Reilly's.
YB = Yellow Bottle (Pennzoil)
Latest list with all additions.
AAP = Advance Auto Parts
ADBV = Anti Drain Back Valve
AF = Air Filter
API = American Petroleum Institute
API-TC = 2 cycle, air cooled engine oil specification
AW = Anti-Wear
AZ = Auto Zone
BITOG = Bob Is The Oil Guy
BOGO = Buy One Get One Free
BP = British Petroleum
CEG = Castrol Edge Gold
COF = Coefficient Of Friction
CP = Conoco Philips (makers of MotorCraft/Kendall/Philips66 and others)
CRD = Common Rail Diesel
CSK = Checker, Schuck's, and Kragen, auto parts stores now called O'Reilly's
Dino = Regular/conventional Motor Oil(s)
FAR = Free After Rebate
FF = Factory Fill
FF = First Fill
FLAPS = Favorite Local Auto Parts Store
FS = Formula Shell
Fuchs = European MFG of quality lubricants
G-oil = GREEN Motor Oil, from Green Earth Technologies
GC = German Castrol...Castrol Syntec, It will say "Made in Germany" on the back. New name, changed to Castrol Edge
HDEO = Heavy Duty Engine Oil
HDMO = Heavy Duty Motor Oil
HM/HMO = High Mileage/High Mileage Oils
HTHS = High Temperature, High Shear rate viscosity
IDK = I Don't Know
IDR = I Don't Recall
IIRC = If I Recall/Remember Correctly
ISO = European Standards
J300 = SAE engine oil viscosity classification standard
JASCO = Japanese Standards
KV = Kinematic viscosity
LIM = Lower Intake Manifold
LOS = Lucas Oil Stabilizer
M1 AFE = Advanced Fuel Economy
M1 EP = Extended Performance
M1 ESP = Emission System Protection full synthetic deisel oil
M1 = Mobil 1, all Mobil 1 oils are full synthetic
M5K = Mobile 5000 mile Dino oil, discontinued
MC = MotorCraft...Not Mobil Clean
MM = Maintenance Minder
MMO = Marvel Mystery Oil
MOA = Motor Oil Additive
MOFT = Minimum Oil Film Thickness
MOS2 = Molybdenum Disulphide
MS5k = Mobil Super 5000
NMMATCW3 = National Marine Manufacturers Association
OBD = On-Board Diagnostics/engine codes
OCD = Obsessive Compulsive Disorder
OCI = Oil Change Interval
OCOD = Orange Can of Death
OD = Over Dose
OEM = Original Equipment Manufacturer
OLM = Oil Life Monitor
OP= Original Poster
OP = Oil Pressure
OPE = Outdoor Power Equipment
O'R = O'Reilly Auto Parts
OT = Oil Temperature
OUO = Oil of Unknown Origin
P1 = Pure One oil filter
PC = Petro Canada
PCMO = Passenger Car Motor Oil
PO = Previous Owner
PP = Pennzoil Platinum
PU = Pennzoil Ultra
PYB = Pennzoil Yellow Bottle
QSDefy = Quaker State Defy
QSED = Quaker State Extended Durability
QSGB = Quaker State Green Bottle
QSUD = Quaker State Ultimate Durability
RL = Red Line oil
RP = Royal Purple
SBC = Small Block Chevy
SLOB = Street Legal Octane Booster
SOPUS = Shell Oil Products United States
ST/STD = SuperTech/SuperTech Dino
STS = Super Tech Synthetic
TC = Spec for low ash 2 cycle air cooled engine oil
TCW3 = Spec for no ash 2 cycle liquid cooled engine oil, W means Water cooled
UCL = Upper Cylinder Lubricant from Lucas, a gasoline additive
UIM = Upper Intake Manifold
UOA = Used Oil Analysis
VDB = Valvoline DuraBlend
VI = Viscosity Index
VML/ML = Valvoline MaxLife/MaxLife
VOA = Virgin Oil Analysis
VSET = Valvoline Synpower Professional Engine Treatment
VSOT = Valvoline synpower oil treament 15 oz VSOT (Valvoline Synthetic Oil Treatment)
VWB = Valvoline White Bottle
WPP = Warren Petroleum Products
XOM = Exxon Mobil
YMMV = Your Milage May Vary
