You know, I happened to have owned a set of those Firestone recalled tires years ago, had put them on a 3/4 ton Chevy 4x4 hauling a heavy camper and boat.
Tires had maybe 3k miles on them when we headed up to Alcova, Wyoming to go fishing for a week - back tire passanger side, while doing 65mph, blew.
Man was that a thrill trying to get that load over to the side of the road; tire had peeled like someone took a can-opener to it.
Long story short, Firestone replaced all 4 tires, no questions asked.
I have used other Firestone/Bridgestone tires since with fantastic results and don't hold Firestone at fault for anything - any manufactorer can come out with a defective product at some point.
I honestly feel that Ford was to blame for this too, as in their psi specs on the door, they are listed way low for a vehicle of that size. AND, if what Capriracer says is true, Ford keeping their psi at a lower level to prevent tip-overs, that tells me a lot about Ford and their responsibility in the tip-overs too.
I have seen first-hand from following a friend in a Ford Explorer, along the same path I've taken numerous times in my Isuzu Rodeo, how tipsy the Explorer really is.
Don't get me started on Goodyear tires.
