quote:
Originally posted by Pete:
That about says it all...
No, it really doesn't. Some of what he says is correct, some is not. For example, with respect to running oil longer than 3k, he states that oil, "still collects the same number of contaminents as a dino. And do you really want that extra crap floating arround in your engine for an extra 2000 miles?" If you're using a decent filter, the very small amount of stuff the 1MZ generates will be trapped in the filter, and not "floating around" in the engine. And further, isn't it pretty apparent from all our good UOAs, dinos included, that 3k changes are excessive in all but the most severe service?
Second, from my own experience with two different 1MZ equipped vehicles, 5k intervals with Mobil-1 or GC are not at all excessive. I had the front head/valve cover off of my second 1MZ off at somewhere between 25k and 30k miles, and it was utterly spotless, without even any varnish discoloration. It looked like it was being assembled at the factory, it was that clean. I'd even pushed a couple fills of M-1 to over 7k miles, and it stayed this clean.
Third, he does not mention the upgrades Toyota made to the 1MZ during the 02 MY. I'd still be cautious with any 1MZ, but the newer ones should be less prone to sludge as a result. But extra care and attention are still warranted for the newer 1MZs since the extended "sludge warranty" does not apply to these cars.
Fourth, while I appreciate anyone taking the time to offer their input, I've had an experienced Toyota service
manager (who has a history as a technician himself) tell me that using synthetic is an effective way to stave off the sludge monster. With all due respect to the new member, I'll take the word of my known-to-be-experienced service tech over an unknown lube tech.
On the other hand, in fairness, the rest of what he says is correct. The 1MZ really thrives on premium gas. It will burn regular, but the ECU will be retarding timing. Not only does this result in even hotter heads, but you can really feel the power being reduced. He's also right that you
can successfully use dino oil, but if you do, you
must be careful not to exceed its inherent limitations.
