Just got back from Autozone,Dad had the code wrong,it is 1491.
A quick copy and paste from a Nissan Sentra site;
***your looking at about 300$ or so.... i've had this p1491 since summer 2005, never fixed it, the car still runs fine, with that said you should fix it when you can afford it.... check out the following found online:
"The computer code P1491 is an evaporative type code, which means the system/component in question aids in handling gasoline vapors from the gas tank. Most of these system components are located at the rear of the vehicle.The evaporative type code rarely causes a driveability complaint."
(http://www.alldata.com/techtips/2004/20041215b.html)
However in the US from what i understand, you gotta watch out for emissions tests, cause this code essentially means that your polluting; the fumes from the gas tank are not being sent to the combustion chamber to be burnt off, but released.***
***Ok, went back to the dealer and they found that the Vacuum cut valve had been installed upside down. No SES light since.
Here are parts cost (canadian price):
Vacuum valve: 18$
Vacuum valve bypass valve: 136$
Canister : 200$
If I were you I you would inspect the canister first because it's a very fragile part.***
***My SE started throwing the P1491 code last year. The vacuum cut valve and the bypass valve needed replaced; no SES light since.
The only recommendation I can give is to not top off your tank when filling up. Stop when the pump clicks off***
How hard would it be to replace the vacuum cut valve and the bypass valve? What do they look like and where are they
