So the other day, it comes on. Engine's running great, coolant and oil perfect as usual, temp gauge normal, no oil pressure light, oil level up, oil filter hot. Alternator charging with a full load (AC, headlights, wipers, etc) at 14.5 VDC. All accessories running as advertised. It went off after a few hours run-time (not a fuel issue that I know of, I hadn't filled the car up since the CEL came on, but the cap is/was tight at the time). I called the stealer (car's under warranty and even though the light went out, they wanna see what the code was that tripped the light). I made the appointment, and Saturday the light came on again. Since I had replaced the battery last fall from the puny, weenie battery the factory put in it to a big bad DuraLast that was probably bigger than the dealer will want to see, I went and bought one more appropriate to the car and installed it today. The car was off battery power long enough to wipe my radio presets, maybe a half hour. Lo and behold, the CEL is out again at startup after the new battery went in, and hasn't come on since (over the course of 50 or 60 miles today since I flopped the battery).
I thought under OBD II, a CEL stayed up until such time as the code is read, cleared, and the light canceled via the diagnostic. Why's it coming and going? COULD a battery with great capacity set a code that would fire the CEL up? And, why'd it go out when no diagnosis has been done on it? The CEL is on at startup and clears 5 seconds after engine on, as advertised. Anyone gotta cloo? Are there errors/alarms/conditions that could come and go and cause the light to come and go? It goes to the Stealer tomorrow regardless. I've already rattled their chain on this so I have to take it to them, but just curious if this makes sense to anyone in the know on OBD..
