Info on Pro-one?
Texas
New company, I believe same guys that started Prolong. They are introducing a new line, covers all the bases, and the big display is the same bearing test they did with Prolong. Its pretty impressive to someone like me, with little technical knowledge of cutting oils, lubricants, etc.
Does anyone have any insight into this? Supposedly the new line is not Prolong, not petroleum based...
Thanks In Advance
If this is an additive I would stay away from it- refineries add all that is needed when manufacturing the oil. it also changes the chemistry of the oil you use. I used prolong years agao in my old Ford- didn't really see any benefit for the cost of it. Just my two cents...
