2007 F350 6.0 Powerstroke
ESSO XD3 0W40
0L make up oil
7,540 km on oil
16,000 km on truck
06/28/07 Sample date
Blackstone Comments: This engine can still be considered fairly new at 16,000 total KM, so we suspect most of the wear metals are from break-in of new parts, while silicon is due to sealers used when the engine was assembled. If that’s the case, then we should see a nice improvement in both areas next time. Universal averages show typical wear from this type of engine after about 8,100 km use on the oil. Fuel isn’t high enough to call a problem at 1.5%, though it is something to watch. Everything else looks fine. Check back in 8,000-9,000 km next time. Things should look better.
Element/Unit/Universal
Al/3/3
Cr/3/1
Fe/59/22
Cu/10/3
Pb/3/3
Sn/1/1
Ni/1/0
Mn/1/0
Ag/0/0
Ti/0/0
K/15/4
Si/52/11
Na/5/3
Ca/3430/3117
Mg/9/83
Mo/7/30
B/2/33
P/1113/1120
Zn/1303/1284
Ba/0/2
SUS Visc @210F= 60.1 should be 60-74
Flashpoint in F= 395, should be >410
Fuel %=1.5, should be Antifreeze =0
Water% =0.0, should be Insolubles = 0.3, should be <0.7
ESSO XD3 0W40
0L make up oil
7,540 km on oil
16,000 km on truck
Al/3/3
Cr/3/1
Fe/59/22
Cu/10/3
Pb/3/3
Sn/1/1
Ni/1/0
Mn/1/0
Ag/0/0
Ti/0/0
K/15/4
Si/52/11
Na/5/3
Ca/3430/3117
Mg/9/83
Mo/7/30
B/2/33
P/1113/1120
Zn/1303/1284
Ba/0/2
