Consensus on 12 month interval oil changes
by accobra66
06/25/16 09:11 AM
Truck Wars
by AirgunSavant
06/25/16 09:06 AM
A good read....The more things change....
by ryan2022
06/25/16 08:46 AM
Opinions on linksys 1900acs router
by madRiver
06/25/16 08:18 AM
Pick my oil change
by ram_man
06/25/16 08:09 AM
Weird!
by AirgunSavant
06/25/16 08:05 AM
Good Deed?
by AirgunSavant
06/25/16 08:02 AM
Vibration after rotating tires and painting wheels
by Drew99GT
06/25/16 08:02 AM
BIBLE STUDENT GONE?
by Eddie
06/25/16 06:23 AM
Avoiding short trips like the plague
by FordCapriDriver
06/25/16 03:11 AM
API CK-4
by JustPlainFolks
06/25/16 02:37 AM
Rotella T
by momo
06/25/16 01:51 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
86 registered (accobra66, AirgunSavant, adamrc, AandPDan, 2015_PSD, 9 invisible), 1598 Guests and 14 Spiders online.
58257 Members
66 Forums
250777 Topics
#980229 - 09/02/07 10:42 PM 85W-140 Gear Oil Too Thick?
njohnson Offline
Loc: Indiana
Hello,
My Dad has a Kubota 105X tractor, and I'm planning on changing the front axle case oil. The owner's manual calls for either Kubota UDT fluid or 80W-90 gear oil to be in the front axle.
I have been shopping around my local auto stores, Rural King, and TSC for a good gear lube. The better quality 80W-90 gear lubes are ranging anywhere from $9 to $14 a quart! I need eight quarts! Whew!
Rural King has Mystik 85W-140 in stock for only about $2.79 a quart. The back of the bottle makes it sound like good stuff, but I am concerned with the viscosity. Is 85W-140 gear oil too thick for an application calling for 80W-90 gear oil?
I would be grateful for any thoughts, comments, and opinions.
Thanks
#980230 - 09/03/07 05:06 AM Re: 85W-140 Gear Oil Too Thick? [Re: njohnson]
unDummy Offline
Loc: RI
It'll only be too thick when cold. Once the gear oil warms up, it will be OK.
Is eight quarts for the front end only? If so, sounds like its overengineered and doesn't need the 'thick gear oil bandaid'. I would shop around and try to find a 90wt.
Most synthetic 90wts around here are ~$10. I would think that the blends or mineral ones would be much cheaper. Why not find the Mystik 90wt?????
#980231 - 09/03/07 08:04 PM Re: 85W-140 Gear Oil Too Thick? [Re: unDummy]
Schmoe Offline
Loc: Oklahoma
I believe that is what's called for in my rear diff. on my F150 so it can't be all that bad.
01 Supercrew Lariat 4X4
06 Accord EX V6
10 CRV EX-L
(traded 02 Accord EX V6 @ 208K miles for)
14 CRV EX-L
(traded 10 CRV for)
#980232 - 09/03/07 09:14 PM Re: 85W-140 Gear Oil Too Thick? [Re: Schmoe]
njohnson Offline
Loc: Indiana
unDummy,
Yes, eight quarts for the front end only. Kubota made the front axle a seperate gear case even from the front wheels. Since the 105X tractor has bi-speed turning/optional 4-wheel drive, the front wheels have gear boxes right behind them, attached to the end of the front axle. That means there really three seperate gear boxes! All with their own drain and fill plugs!
It is quite the impressive machine. That is why I want some kind of gear lube in the axle case instead of the optional UDT transmision fluid. The UDT fluid just seems like it would be a kinda thin viscosity fluid for the axle case for such a heavy machine.
I have looked for the Mystik 90wt, but I can't find it! It is a little frustrating with the limited number of products that I can find locally. I guess the reason Rural King stocks the 140wt is because it is the most common viscosity for heavy duty applications?
Schmoe,
It's funny you mention your F150, my Dad has a 2006 Tundra, the owner's manual calls for a 140wt gear lube in the standard rear diff., however, for the limited slip diff. it calls a 90wt. gear oil. The equipment manufactor's recommendation of the fluids they would like you to use sure are a lot of fun, aren't they?
#980233 - 09/04/07 03:00 AM Re: 85W-140 Gear Oil Too Thick? [Re: njohnson]
bruce381 Offline
Loc: Millbrae, CA
""Is 85W-140 gear oil too thick for an application calling for 80W-90 gear oil?""
For slow speed as in your use NO go ahead and use it it will be fine.
bruce
#980234 - 09/04/07 06:37 AM Re: 85W-140 Gear Oil Too Thick? [Re: bruce381]
njohnson Offline
Loc: Indiana
I appreciate all the replies.
bruce381, thanks for saying the 140wt is fine to use. You wrote "For slow speed as in your use ". What is the difference between slow speed or high speed using the 85W-140?
#980235 - 09/04/07 11:45 AM Re: 85W-140 Gear Oil Too Thick? [Re: njohnson]
99 Offline
Loc: SW burbs of Chicago
I use 85w140 in the front/rear diffs of my Jeep. This thicker gear oil usually comes from the factory in the rear diff of trucks/suvs that will see towing duty, so take that for what it's worth. I've had no problems with it. When cold it flows like a, well, 85w rather than a 80w. Go for it.
97 4.0/auto Jeep Wrangler
04 2.0/auto VW Jetta Wagon
06 6.0/6sp Pontiac GTO
#980236 - 09/05/07 03:00 AM Re: 85W-140 Gear Oil Too Thick? [Re: 99]
bruce381 Offline
Loc: Millbrae, CA
slow heavy loads will like a thicker oil if highway speeds oil churning may reduce mileage some but in general gears sets like the thickest oil you can run at the temp range you are in. I use 75/140 syn both front and rear on all my 4x4.
bruce
#980237 - 09/05/07 08:23 AM Re: 85W-140 Gear Oil Too Thick? [Re: bruce381]
marco246 Offline
Loc: Hawaii
njohnson,
This probably is not what you want to hear, but. . . .
The Kubota UDT is perfect for your tractor. Or, if you don't want to stick with the house brand (maybe it's pricey), you can pick up a 5 gallon pail of something like Chevron THF 1000 for $57 here in Hawaii, probably less in Indiana. It meets Kubota's specs. Anyway you look at it, it's pretty cheap and does the job.
Cheers, Mark
15 Alfa Romeo 4C PP Euro 5W-40
10 Honda Insight M1 0W-20
06 Frontier Chevron 5W-30
64 Cobra 289 Delo 15W-40
#980238 - 09/05/07 07:49 PM Re: 85W-140 Gear Oil Too Thick? [Re: marco246]
unDummy Offline
Loc: RI
The UDT/Super UDT are 9-10cst fluids. 80w90 gear oils are typically 14-16cst, which is already cosiderably thicker.
With winter coming, and not knowing the lubrication method in those gear boxes(splash, pumped, wings, groves, combination), I would probably NOT go to a 140wt unless it was a full synth($12-$15/quart). If your location was along the equator, I would not fear the '85w'-140wts as much.
There are several manual trannies that do NOT tolerate thicker gear oil. The gear oil flow is reduced and the gears/bearings are starved of coolant/lubricant. Why risk that with your gearboxes?
Just be glad that Kubota gives you a choice in place of the factory fill. Since 90wt gears oil are an easy find, I would just pay up and use them.
