Hey, all,
My new (to me) '03 Buick PA gives a mild groan when I'm turning left. Only left, not right, and not loudly, only audible when the windows are down. If it were a loose belt or low fluid, the steering would make noise in either direction, right? (And in any case GM has tucked this car's steering reservoir away with such delicate modesty that I can't find it to check the fluid!)
Is my memory right -- is this likely to be something up with the steering components on that side -- or could it be a belt/low fluid?
