Hi
For the technical experts below is the composition of a Lead
replacement additive which can also be used in normal unleaded
engines as an injector cleaner and UCL upper cylinder lubricant.
It is also used in LPG gas conversions to protect from valve seat wear.
Claims it is safe for all catalytic converters.
Kerosene CAS 8000-20-6 0-10%
White Spirit CAS 8052-41-3 0-10%
Iscooctly Alcohol CAS 26951-21-6 0-10%
Potassium Carboxylate 0-10%
Other ingredients not hazardous to 100%
Treat rate ratio is 1 to 1000 litres of unleaded fuel.
Any comments on the formula?
Virginoil
Virginoil
