Quote:
G, I don't disagree at all. That part is marketing clearly. Point I was making is Honda chose Mobil 1, not the other way around.
And we often here how M1 isn't better than conventional oil etc etc (in most cases it's not bc the conditions dont' demand it)....but these types of turbo engines and certain other environments (extreme cold/long drains) show the superiority of a good synthetic oil like Mobil 1. I'd like to know what oil Bill from Utah would run in this vehicle?
Wear metals on a ppm basis in a Toyota Corolla drained at 5k miles won't show why Mobil 1 is as good as it is.
Buster,
*if* I had a honda that needed this spec, I'd run whatever passed the spec and was on sale. If its PP than thats what it would be.
If I had to pay full price, it would be PP or something else than Mobil 1 because I'm not impressed with Mobil.
As far as Mobil 1 having worst performance in a 5k OCI over a conventional oil for the same OCI, I guess you'll pay the $$$ over the life of the engine using Mobil 1 and I'll just run (damage) my engine to 300k plus using conventional oils.
So do you really think that having more wear metals in a certain time frame (like 5k miles) in a UOA is better than a lower number?
Oh, I forgot..
Can't trust or believe a $20 UOA.
(unless its showing your engine/oil/type to performing low metals...)
Remember, I've taken many engines well past 200k with never an issue. And all I've ever run is cheap trash oil (trash since its not $5 plus a quart).
I'll pocket the $$$ that others spend. I KNOW what works and what is hype.
For
normal motors, Syn is not needed. Wanted is another thing. But don't think that its some magic for your engine.
Its magic for oil companies.
I've had engines sit outside in well below zero. Started everytime. My 315k plus VW had 10w-30 SG/sh conventional oil in it for a long time before 5w-30 came out. Its made over 300k and still running fine. Passes smog and never had the injectors off, never had a single problem.
How does it run?
This is the major reason why once I'm done with my prepaid UOA kits, I'm done posting them here.
Its obvious I'm clueless.
I don't want the best and don't want my engines to last..
Who needs the hassle.
Bill
PS: And I just changed my oil in my Corolla with PP today. Why PP and a Syn? Cause it was the only oil on sale at the time I bought it. See, I'll run syn. Not because its syn, because its cheap.
PPS: And I'm going to do a UOA. And post it here. (so I guess when its wear metals is lower than Mobil 1, we better come up with a reason...)
