I absolutely KNOW I posted this yesterday, yet my post is gone. Weird.
Anyhow, repost. For the 5.7L 8-cyl Engine code D:
Code:
Manual Transmission,Getrag 238.....AP4
Synthetic Automatic Transmission Fluid
Manual Transmission,TREMEC T56.....GL-4
75W-85[3]
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Manual Transmission,G56.....AP4
Automatic Transmission.....AP4[4]
Differential, Front 9.25 AA.....GL-5[5]
All Temps......75W-90
Severe Gear 75W-90
Differential, Front 9.25 AA EL.....GL-5[5]
Severe Gear 75W-90
Differential, Front C205FD.....GL-5[5]
Severe Gear 75W-90
Differential, Rear 10.5 AA.....GL-5[5]
Severe Gear 75W-90
Differential, Rear 10.5 AA EL.....GL-5[5]
Severe Gear 75W-90
Differential, Rear 11.5 AA Open.....GL-5[5]
Severe Gear 75W-90
Differential, Rear 11.5 AA Trac-Rite.....GL-5[5]
Severe Gear 75W-90
Differential, Rear 248RBI (Dana 60).....GL-5[6]
All Temps......90
SAE 80W-90 Synthetic Gear Lube
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Differential, Rear 9.25.....GL-5[7]
All Temps......75W-140
Severe Gear 75W-140
SAE 80W-140 Synthetic Gear Lube
Transfer Case,.....AP4
Fluids
Power Steering Fluid.....AP4
Brake Fluid.....HB
Clutch Fluid.....HB
1. Vehicles with the 5.7 Multiple Displacement SYS (MDS)
must use SAE 5W-20 oil. Failure to do so may result in
improper operation of the Multiple Displacement SYS (MDS).
2. Vehicles with the 5.7 Multiple Displacement SYS (MDS)
3. 75W-90 GL-4 is a synthetic gear oil, Mopar Part No. 4637579
or Castrol Syntorq are recommended.
4. DaimlerChrysler Corp. recommends that all vehicles with
Chrysler ATS be serviced W/ ATF+4
ATF.
5. Synthetic based oil.
6. Add 147 ml (5oz) of limited slip additive
7. With Trac-Lok add 118 ml (4oz) of limited slip additive
Tell us more details and I can narrow it down a bit.
