I have a 10 year old 14" Poulan that gets very little use. Yesterday I needed it to cut down an overgrown 18' Yew and it wouldn't start/run. Here's the run down:
Filled oiler, filled fuel tank.
Tried to fill the primer bulb - after numerous presses the bulb showed no signs of getting fuel and engine wouldn't fire up.
Turned engine on it's side (primer bulb up) and was able to get the bulb to draw fuel. Was able to get the engine to fire up briefly (5 second run) then it died. Wouldn't re-start.
Again couldn't draw fuel into the primer bulb unless turned on it's side. Engine only runs for several seconds and then dies.
Able to prime and start the engine, then quickly turn entire saw on it's side (again with primer bulb up) - now able to run engine for longer time (15-30 seconds) until it dies. Working the throttle allows the engine to run, but once the saw is turned right-side up it quickly dies.
The saw ran fine last Fall, it was stored with a small amount of stabilized fuel in the tank. Also, it was stored on it's side (primer bulb and fuel cap up)
Since the tank is still half full I can't see in there - I plan on draining the fuel tomorrow.
I'm curious if this is a common problem with some common remedy? It's seems that it's a fuel system problem.
Any Thoughts?
BTW - ended up cutting the Yew with a bow saw and lopping shears
Any Thoughts?
