Ok, two part post here. First part is wheels, second part is tires.
First of all, the wheels. The truck I am buying is a 1971 Ford F-250, 3/4 ton, 2-wheel drive, old farm truck. It has the original 16.5-inch wheels on it and generic tires. So it will need the tires replaced but I'm having serious trouble finding 16.5 inch tires. TireRack certainly doesn't have many choices, I think there's a Kumho or two and a couple Firestone/Bridgestones and one Toyo. So that's not so good. Should I insist on changing over to 16" wheels before I try and buy tires?
Secondly, as for the tires, does anyone know of any 16.5-inch tires besides the handful on TireRack? If not, I'm probably going to go 16-inch and grab a set of BFGoodrich Commercial T/A's.
edit: forgot to mention usage...the truck will spend half of its time commuting me to and from work on nice paved highways. The other half will be split between driving on back roads in the county to and from markets and stores, and carrying heavy loads on the highways to and from the ranch. By heavy loads I mean 1000-1500lbs, not nearly at the bed's capacity but certainly more than just my fatness...
