Your FINAL though on Quaker State oil line
by MetalSlug
07/27/16 07:45 AM
Amsoil SS 5w30, 10K, 04 Chevy Tahoe, 206K
by dhellman12
07/27/16 07:30 AM
2004 Chevy 2500HD, 60k Amsoil ATF, 194K
by dhellman12
07/27/16 07:17 AM
The History of Snake Oil
by Char Baby
07/27/16 07:16 AM
Industrial hand cleaners?
by KenO
07/26/16 11:58 PM
Shell Rotella T6 in a Altima 2.5
by Grambo
07/26/16 11:24 PM
"Creaking" Conti DWS's?
by Lolvoguy
07/26/16 10:52 PM
Check your car after it's been worked on
by Nick1994
07/26/16 10:15 PM
How are lg android devices now days?
by ram_man
07/26/16 09:42 PM
Dexos 5w30 with highest 100c Viscosity
by CapitalTruck
07/26/16 09:32 PM
How do you avoid being perceived as a rookie when
by motor_oil_madman
07/26/16 09:27 PM
Oil opinions after dumping FF
by JoelB
07/26/16 09:27 PM
snydercn, surfbum, Tmemz4, woollum86, Phil108
58612 Registered Users
63 registered (Asterix, Bandito440, Bamaro, Anduril, badtlc, bbhero, 3 invisible), 1584 Guests and 16 Spiders online.
58612 Members
66 Forums
252300 Topics
Page 1 of 2 1 2 >
#959961 - 08/07/07 08:34 PM Yamaha FJR Oil
Scout1 Offline
Loc: Seattle WA
I have a 2007 Yamaha FJR 1300 cc bike bought new a couple of months ago. After a brief stint with Yamalube, I'm on my first fill of Rotella-T-Synthetic 5w-40 wt. and all seems to be going well.
My question is about the advice in my owner's manual concerning the oil to use. Here is what it says:
"In order to prevent clutch slippage, do not mix any chemical additives. Do not use oils with a diesel specification of "CD" or oils of a higher quality than specified. In addition do not use oils labeled "ENERGY CONSERVING II" or higher." Then it goes on to specify Yamalube 4 20w-40 or SAW 20W40 API service SG or higher, JASO standard MA.
I understand the part about no additives and no ENERGY CONSERVING II oils due to the wet clutch. Buy why the no CD diesel oils and why the statement not to use a higher quality oil than specified? What's unique about CD diesel oil? My Rotella-T-Synthetic is a diesel oil and I'm wondering if it's OK to run...am I missing something?
Scout1
Truth will always bear up against falsehood, as oil does above water
#959962 - 08/07/07 11:42 PM Re: Yamaha FJR Oil [Re: Scout1]
unDummy Offline
Loc: RI
I would think that it is translated as "CD or higher", which leaves out most newer diesel oils which are CI and CJ now. So, there is nothing unique to 'CD'.
If you have clutch slippage, upgrade the clutch plates and springs. Build those hand, wrist,& finger muscles.
It looks like they want a thick 40wt narrow range motor oil. Narrow weight range to prevent quick shearing in a high rpm motor. Older oils used abundance of tried/true ol' school additives. Newer additives, like friction modifiers, are being used now. These might cause issues with the clutch. They also might not be up to the task of higher rpm wear and tear that you'll encounter.
There are plenty of motorcycle oils to choose from. I would definitely stick with one.
Whether Rotella-T synth is OK to run is for you to decide. I doubt it would hurt anything. UOA's can be used to determine whether it is appropriate.
#959963 - 08/08/07 01:20 AM Re: Yamaha FJR Oil [Re: unDummy]
Hammer Offline
Loc: Goose Creek, SC
I forget what it is, but CD rated Diesel oil is not very good. This does not translate as you said and thus newer Diesel ratings are OK.
To the original poster, using Rotella 5w-40 synthetic is a good choice and will treat your engine well.
Hammer
06 BMW K1200R
02 Corvette Z06
01 F250 7.3 PSD
00 BMW 328i
97 Yamaha YZF1000
two Cummins ISX & one N14 Diesels
two Yanmar/Thermoking Diesels
#959964 - 08/08/07 05:18 AM Re: Yamaha FJR Oil [Re: Hammer]
Reg# 43897 Offline
Loc: Fredericton
I have an '03. I have run the older style red cap Mobil 1 15w-50 for a while. Once that became scarce I snagged a heckuva deal on a pile of Mobil D1 5w-40 (and still have five or six jugs left). Have been using Shell RTS like you. That stuff just plain rocks. Have also used regular Rotella T once and it ran very well. I like the supposed synthetic edge but I admit that it has little benefit in a wet clutch shared sump. The price of RTS for such a good quality oil keeps my attention. All of the above mentioned oils have performed flawlessly - NEVER a clutching issue. The shifting is always fine. I have a couple of samples that I have to send off to Blackstone which should prove interesting.
By the way, many here have commented that RTS holds up very well under fuel dilution. The used oil in my FJR reeks of fuel... For what it's worth.
John.
#959965 - 08/08/07 07:24 AM Re: Yamaha FJR Oil [Re: Reg# 43897]
Scout1 Offline
Loc: Seattle WA
How often do you change the oil in your FJR? Is the fuel contamination a normal thing for this bike? My FJR is getting about 44 mpg which is about the same as my last bike, a 1979 Yamaha XS1100.
Also, would like to know your oil analysis results, are they posted? I've been thinking about doing some testing on the FJR once it gets a few more miles on it, but also testing the oil in my wife's 2001 Audi TT. We just fixed a mass airflow sensor problem on the TT so I think it was running a bit rich while it tried to compensate. Maybe the next change would be a good time to pull a sample at 4 or 5k miles. I'm running the RTS in that too...
Scout1
#959966 - 08/08/07 07:35 AM Re: Yamaha FJR Oil [Re: Scout1]
Reg# 43897 Offline
Loc: Fredericton
As I said, the samples have yet to be sent off... The last sample was run a little longer than my usual. It went around five thousand kilometres with a Pure One filter. That was a witches brew of D1 and red cap. The current sample is RTS and a Baldwin. I'm looking forward to the results once it gets sent. If I flog it the fuel economy is around 40 -45 mpg(Imp.) while normal commute is around sixty to sixty-five or so.
John.
#959967 - 08/08/07 09:33 AM Re: Yamaha FJR Oil [Re: Reg# 43897]
Scout1 Offline
Loc: Seattle WA
Hummm... that's a little better fuel economy than mine if I've done the conversion to imperial gallons correctly. Perhaps it just that mine is still breaking in, but I wonder if my fuel injection is off a bit. I think the manual calls for a fairly early check of the fuel injection calibration. Maybe I ought to get that done...
Scout1
#959968 - 08/08/07 08:09 PM Re: Yamaha FJR Oil [Re: Scout1]
Reg# 43897 Offline
Loc: Fredericton
Have you gone to the FJRForum.COM yet? If not, then do so. The early adjustment of which you speak is likely the fuel injection synchronisation. If you get a synch tool you can do that yourself. It just lowers vibration more than anything but it can be a dramatic change for a relatively small adjustment.
As regards fuel consumption, your engine is new. Every modern electronically controlled engine that I have used in the last while ALWAYS gets terrible fuel economy at the start while the fuel system is babying the engine. Our new Patriot was only getting 22 - 23 mpg(short) for the first four thousand kilometres or so. It's suddenly shot up to 35 - 36 at the five thousand mark...
My conversion is a short gallon is equal to 3.98L. A gallon Imperial is around 4.5L if that helps.
John.
#959969 - 08/08/07 08:18 PM Re: Yamaha FJR Oil [Re: Reg# 43897]
ccs v2.0 Offline
Loc: IL
There's the difference, a US gallon is 3.79L
The light at the end of the tunnel is the Recession Freight Express Train coming at us. - Al, 11/07/07
#959970 - 08/08/07 08:37 PM Re: Yamaha FJR Oil [Re: Reg# 43897]
Scout1 Offline
Loc: Seattle WA
Thanks for the tip. I'll check out the FJRForum. I did some reading before I bought the bike and heard about the early "tickers" which was one reason I wanted to find the best oil for the bike... and here I am at BITOG!!!
I'll look into the syncronization of the fuel injection. What sort of tool do you need? I have the old "carb stix" I used to sync the carbs on my old 1100... is it the same tool on a fuel injected bike?
My bike has been steadily getting better fuel economy as it breaks in. Initial tanks got about 40 or so. I was up to 43 when I put the change of Rotella in and the tank after that jumped to 47. Cool I thought, but the last two tanks have been about 44 (maybe how I've been riding it? ). On the plus side, the on-board computer seems to be dead on in terms of accurately calculating the gas mileage.
Scout1
#959971 - 08/08/07 11:17 PM Re: Yamaha FJR Oil [Re: Scout1]
arkie6 Offline
Loc: Russellville, AR USA
Quote:
...Then it goes on to specify Yamalube 4 20w-40 or SAW 20W40 API service SG or higher, JASO standard MA...
They do that to sell Yamalube, which is the only brand of oil I have seen in the 20W-40 viscosity rating.
#959972 - 08/09/07 02:04 AM Re: Yamaha FJR Oil [Re: arkie6]
Jim 5 Offline
Loc: Calgary Canada
I agree. My '87 FJ1200 asked for yamalube 20w-40 and I ran it on 15w-40 HDEO for years and years. When I took the engine apart to replace second gear, the internals/bearings looked perfect, and the crank bearings plastigauged within spec.
I wouldn't hesitate to use a HDEO 15w-40. I have asked the question here which would be more shear stable, that or a 5w-40. The answer from the experts when comparing delo synth 5w-40 and delo 15w-40 is that the 15w-40 is more shear resistant.
I'd like to see a UOA on yamalube just to see how different in viscosity and additives it is to an HDEO.
Jim A
07.5 GMC Sierra 2500HD LMM Rotella 15w-40
09 Odyssey EX-L CT 5w-20
66 Bronco QS 10w-30
08 BMW K1200S Rt 15w-40
08 Pitster Pro X4 Rt 15w-40
#959973 - 08/13/07 06:21 AM Re: Yamaha FJR Oil [Re: Jim 5]
Jim 5 Offline
Loc: Calgary Canada
FYI
15w-40 HDEO vs. 5w-40 HDEO Synth Shear Resistance Thread
Some heavy-duty BITOG oil minds weighed in on the subject...in case it would help.
Jim A
66 Bronco QS 10w-30
#959974 - 08/21/07 07:42 PM Re: Yamaha FJR Oil [Re: Scout1]
kballowe Offline
Loc: East Central Missouri
I've sync'd half a dozen FJR1300s and they've all been very close. Once you pivot the tank up and put a stick under it you'll notice that each throttle body has an access tube. Remove the little rubber thingys and just hook up an old mercury gauge - you know, the one with the mercury and the glass tubes. Pretty easy to sync. You'll see once you get in there.
A far as the Rotella, many FJR owners use it and are pleased. Some use the 15W-40 and some use the 5W-40. In a water-cooled bike it would be hard to go wrong with either. Just depends on what oil change intervals you have in mind. I use the 5W-40 in my '07.
#959975 - 08/24/07 07:03 PM Re: Yamaha FJR Oil [Re: kballowe]
Scout1 Offline
Loc: Seattle WA
Thanks, I'll try it. I've got the old mercury stix from syncing my old XS11! I notice my 07 has a heat shield on top of the engine that I don't see in some of the pictures of earlier FJR's. Was that new to prevent rider blow-back of engine heat?
Scout1
Page 1 of 2 1 2 >
