Nissan Titan 5.6L V8 DOHC 315 HP GAS.
I tow a 17 ft. boat alot.
Mobil EP oil filter.
K&N air filter.
3010 Miles on oil. Using Pennzoil Platinum 5W-30.
47,163 on motor. It has seen alot of Pennzoil.
Sample date 7/27/07. No drain - kept using the oil.
Aluminum - 2 Univ. Avg. - 3
Chromium - 1 - 1
Iron - 16 - 13
Copper - 2 - 4
Lead - 1 - 4
Tin - 0 - 1
Moly - 50 - 66
Nickel - 0 - 0
Manganese - 0 - 1
Silver - 0 - 0
Titanium - 0 - 0
Potassium - 1 - 1
Boron - 32 - 64
Silicon - 9 - 13
Calcium - 2716 - 2190
Mag. - 11 - 93
Phos. - 629 - 712
Zinc - 725 - 832
Barium - 0 - 0
SUS VIS - 56.9
Flash - 360 F
Fuel - 0
Antifreeze - 0
Water - 0
Insol. - .2
Blackstone comments - If you hadn't told us you towed a boat with this engine, we would never have after guessed. The Univ. Avgs. column shows typical wear from this type of engine after 4900 miles on the oil. You ran this oil 3010 miles and most wear read below Avgs. Iron is the only one higher, and that's a result from towing. Still, the 3pmm diff. between iron and the avgerages isn't enough to matter. Bearing wear ( copper, lead, tin ) looks especialy good. Trace of fuel elements is harmless. TBN read 4.8, still lots of additive left. Nice engine!
You got to love Pennzoil Platinum !!
K&N air filter.
Chromium - 1 - 1
Iron - 16 - 13
Copper - 2 - 4
Lead - 1 - 4
Tin - 0 - 1
Moly - 50 - 66
Nickel - 0 - 0
Manganese - 0 - 1
Silver - 0 - 0
Titanium - 0 - 0
Potassium - 1 - 1
Boron - 32 - 64
Silicon - 9 - 13
Mag. - 11 - 93
Phos. - 629 - 712
Zinc - 725 - 832
Barium - 0 - 0
SUS VIS - 56.9
Flash - 360 F
Fuel - 0
Antifreeze - 0
Water - 0
Insol. - .2
