I remember reading an article that stated it was 23% ester. This article mentions esters - http://www.superiorpetroleum.com/html/delvac_1.html
Quote:
Evidentally not Turbodiesel truck..... http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Comparing_Delvac1_TurboDiesel.aspx
linkabove said:Answer:
Either brand is a great choice since Mobil 1 Turbo Diesel Truck 5W-40 and Mobil Delvac 1 5W-40 are the same product branded differently for different markets.
Quote:
huh?
Quote:
Obviously it can't outperform itself.
Quote:
Delvac 1 has also shown near zero values for oxidation in VOAs which indicates there's not much ester in it. Esters have oxygen atoms in them so are picked up in the oxidation test.
Quote:
Answer:
Mobil 1 formulas will deliver everything you need for your gasoline engine. In fact, during development, tests are run in both gasoline and diesel engines to demonstrate the superior performance of Mobil 1.
Mobil Delvac 1, which is designed for heavy-duty diesels, meets most diesel engine oil specifications, and also meets API SL certification. And because Delvac 1 operates in a different environment – diesel engines run longer, generate soot and run hotter, it contains different types and amounts of additives than Mobil 1. Even so, Delvac 1 still meets API SL certification for gasoline engines, and because of its high performance, we would expect it to do a good job of protecting your gasoline engine.
Quote:
Diesel engines run longer, they generate more soot, but... they do not run hotter.
Quote:
I'm not familiar with how hot your TDI runs, but most of the bigger Diesels I deal with DO run hotter.
Quote:
http://www.audiusa.com/etc/medialib/cms4imp/audi2/aoa/company/aoa-specific.Par.0004.File.pdf
It appears that the VW 502 approved oil list was updated 8/07 and that M1 Turbo Deisel is on there, in a few different weights than I have seen
