Quote:
I run it in my little brother's 'China-bike' ATV with a 150cc engine. It is constantly tached out when he's riding... it's geared low as [censored]. And it's held that engine together so far. Sometimes it sounds like it would blow up. So, I think it's a good oil as far as that goes..
I assume it's safe to use in wet-clutch systems... as that is what his ATV is, anyways. I might start using it in my Honda Shadow with the shared sump. It's geared low so it's normally running high RPM at 55mph and above. Rotella-T 15w-40 is in there right now... I just want something I KNOW will hold up.
Quote:
Yamalube is good oil practically overpriced overkill oil. trust it.
Quote:
If you want overpriced, overkill, but darn fine oil, give Maxima a look see. Over the top on the additive packages, no matter which level you choose.
And yes, I use it in my regulation vehicles (not bikes).
And where can we score some of this fine oil? link?
