If it runs great with the Bosch plugs, go with it and don't worry.
From what I gather, any plug of the proper heat range and gapped correctly will work well in any car. A new, properly gapped plug will perform better than an old worn plug. That is where we hear all the stories about "my car runs smoother and get a gajillion more mpg than with old brand name X plugs".
Some will past longer in certain applications is the only difference.
My experience with Bosch platinums vs Denso Iridiums...
I replaced the original plugs around 25,000mi on my 2002 Vovlo S40 (turbo). The OEM plugs looked OK and were still pretty close to the original gap spec. Replaced them with Dendo Iridiums. No difference noted upon installation. 25,000mi later the Densos started missing on wide open throtle. I checked and found they had worn by nearly 0.015". Regapping solved that problem but I picked up a new set of OEM Bosch plugs to put in. For me the Bosch platinum OEM plugs last longer at under half the price for Iridiums.
Use whatever plug gives you the longest lifespan vs cost. Your engine management system determines the correct timing so a small peice of this metal or that is not going to impact your performance or mileage in any way you will see.
