My bike has the Shimano Grip Shift Max 21 speed. It appears that something is broken on the right shifter. It does not click or hold the selected gear anymore, so it stays in the highest gear 7. Looks like some part broke off in the inside, so I'll need to replace that whole shifter. The question is if I get another kind of shifter with the same amount of gears (7 speed) like the index shift or any other type, will it work? I don't know if all 7 speeds gearing for the rear are same for all bikes. Thanks.
