Adding a UOA from April -- oil was not tested when changed in February. Test performed by Oil Analyzers Inc.
First number is Delvac. Second number is Elf at 10.6k. Third is the same Elf at 14.0k. Fourth is Delvac at 9.6k. Fifth is Delvac at 9.8k. Sixth is Delvac at 9.5k
May 28 -- July 29 -- August 20 -- October 29 -- Dec 22 -- Apr 29
161421 -- 172095 -- 175508 -- 185142 -- 194915 -- 215121
Iron 38 -- 96 -- 152 -- 77 -- 41 -- 34
Chromium 1 -- 2 -- 3 -- 1 -- 1 -- 2
Lead 2 -- 3 -- 6 -- 3 -- 3 -- 1
Copper 3 -- 4 -- 5 -- 2 -- 2 -- 6
Tin 0 -- 0 -- 0 -- 0 -- 0 -- 0
Aluminum 7 -- 7 -- 6 -- 6 -- 5 -- 12
Nickel 0 -- 4 -- 0 -- 0 -- 0 -- 0
Silver 0 -- 0 -- 0 -- 0 -- 0 -- 0
Silicon 5 -- 10 -- 8 -- 5 -- 1 -- 12
Boron 29 -- 82 -- 57 -- 34 -- 29 -- 41
Sodium 0 -- 0 -- 2 -- 0 -- 0 -- 0
Magnesium 615 -- 367 -- 287 -- 582 -- 491 -- 663
Calcium 2775 -- 3109 -- 2381 -- 2861 -- 2346 -- 3018
Barium 0 -- 0 -- 0 -- 0 -- 0 -- 0
Phosphorus 1231 -- 1133 -- 1108 -- 1422 -- 1256 -- 1299
Zinc 1528 -- 1477 -- 1322 -- 1712 -- 1577 -- 1617
Moly 1 -- 0 -- 1 -- 0 -- 1 -- 0
all others 0 -- 0 -- 0 -- 0 -- 0 -- 0
Fuel Viscosity @ 100C =15.33 -- 11.39 -- 11.52 -- 16.05 -- 16.33 -- 16.36
Water 0 -- 0 -- 0 -- 0 -- 0 -- 0
Soot 1.28% -- 1.64% -- 1.94% -- 1.47% -- 1.25% -- 1.05%
Coolant = none -- none -- none -- none -- none -- none
TBN = 7.35 -- 6.52 -- 6.32 -- 7.44 -- 5.42 -- 8.06
Filter was Wix. Driving pattern was my normal 200-250 miles/day, a mix of city and highway. There were no long highway trips.
The injector nozzles were replaced with Kerma (Bosio) PP520's on Feb 2nd, about two weeks before the Feb 17th oil change. So new nozzles during the entire interval.
Soot is high but trending down. Silicon is just slightly elevated. Copper and aluminum a bit high. Viscosity pretty high, as in recent tests.
Next oil change in early July.
Previous discussion regarding this engine here:
http://theoildrop.server101.com/forums/showflat.php?Cat=0&Number=583320
and here:
http://theoildrop.server101.com/forums/showflat.php?Cat=0&Number=583403
and here:
