I probably should've waited longer for the initial OCI, but I couldn't help it. There were a couple of small particles at the bottom of the oil change pan. The lab did 3 viscosity tests, I'm not really sure if it's an xW20 or xW30. Within the TSB Toyota issued on 5W20 oil use, the NZ-series is approved for it.
Code:
Sample Date 8-JUNE-2007
Analysis Date 15-JUNE-2007
Lab Wearcheck Canada
Make Toyota
Model Yaris Sedan
Year 2007
Engine 1NZFE 1.5L L4
Miles 1100
Oil Brand Toyota OEM
Oil Series Factory Fill
Oil SAE J300 5W30 ? 5W20 ?
API SX NR
Miles on Oil 1100
Months 1.2
Antimony Sb NR
Cadmium Cd NR
Vanadium V 0.3
Aluminum Al 12
Chromium Cr 0.4
Iron Fe 6.8
Copper Cu 70
Lead Pb 1.0
Tin Sn 6.4
Molybdenum Mo 524
Nickel 0.0
Manganese Mn 1.9
Silver Ag 0.2
Titanium Ti 0.2
Potassium K 1.0
Boron B 726
Silicon Si 204
Sodium Na 3.9
Calcium Ca 1719
Magnesium Mg 12
Phosporus P 796
Zinc Zn 900
Barium Ba 3.1
Sulfur 2855
cST @ 100 C 7.9
SUS @ 210 F NR
Flashpoint (F) NR
Fuel % 2.0
Antifreeze % NR
Water %
Insolubles % NR
Sulfation 17
Oxidation 23
Nitration 8
TBN (IR) 3.1
TAN NR
Ferrous Debris NR
Soot % 0
Glycol
ISO Code NR
Additives NONE
ZDDP 24
URL
Location ON, CAN
Air Filter Toyota OEM
Oil Filter Toyota OEM DENSO 90915-10003
Lab Notes: All component wear rates are normal. High concentration of dirt present in the oil. Light fuel dilution occuring. The oil is no longer serviceable due to the presence of contaminants.
Code:
Make Toyota
Model Yaris Sedan
Year 2007
Miles 1100
API SX NR
Miles on Oil 1100
Months 1.2
Antimony Sb NR
Cadmium Cd NR
Vanadium V 0.3
Aluminum Al 12
Chromium Cr 0.4
Iron Fe 6.8
Copper Cu 70
Lead Pb 1.0
Tin Sn 6.4
Molybdenum Mo 524
Nickel 0.0
Manganese Mn 1.9
Silver Ag 0.2
Titanium Ti 0.2
Potassium K 1.0
Boron B 726
Silicon Si 204
Sodium Na 3.9
Calcium Ca 1719
Magnesium Mg 12
Phosporus P 796
Zinc Zn 900
Barium Ba 3.1
Sulfur 2855
cST @ 100 C 7.9
SUS @ 210 F NR
Flashpoint (F) NR
Fuel % 2.0
Antifreeze % NR
Water %
Insolubles % NR
Sulfation 17
Oxidation 23
Nitration 8
TBN (IR) 3.1
TAN NR
Ferrous Debris NR
Soot % 0
Glycol
ISO Code NR
Additives NONE
ZDDP 24
URL
Location ON, CAN
