Quote:
I thought MB dealerships were using the new lower-SAPS Mobil 1 5W-40? I forget it's letter designation but it's not 5W-40 TDT or Delvac 1. Correct me if I'm wrong. Maybe what's factory fill is different from what's used thereafter. Same with VW/Audi in many cases.
If you look at the 229.31 and 229.51 approval lists the vast majority of oils on there are Xw30.
MB sheet 229.31 approved oils; LA "low ash" Oils
Mercedes pioneered this new spec for passenger cars with diesel engines with EURO 4 or Bluetec exhaust particle filters, e.g. W211 E200 CDI, E220 CDI. The spec was introduced 7/2003. They are called LA "low ash" or "low SAPS" oils, low on sulfated ash, phosphorus and sulphur to limit exhaust particle filter pollution. In 2004 the ACEA introduced the new C3 spec (mid SAPS, normal viscosity) based on it. Change intervals extend to 15,000 km.
30
Aral Tronic 229.31 5W-30
BP Visco 5000 MB 5W-30
Castrol FORMULA SLX Turbo Diesel 0W-30
Castrol TXT Softec MB 5W-30
Fuchs Titan GT 1 5W-30
Liqui Moly TopTec 7000 LA
Low SPAsh Motorenöl 5W-30 (DaimlerChrysler) (factory fill)
Midland Synqron 5W-30
Mobil SHC Formula LA 5W-30
Mobil 1 ESP Formula 5W-30 (from 3/2005)
Q8 Formula Special 5W-30
Pento High Performance 5W-30 LA
Shell Helix Diesel Ultra AE 5W-30
Shell Helix Ultra AE 5W-30
Wintershall ViVA 1 topsynth alpha LA 5W-30
40
Aral SuperTronic 0W-40 LOW SAPS (ACEA C3)
Castrol GTD Magnatec 5W-40
Fuchs Titan GT 1 10W-40
Liqui Moly TOP TEC 4100 5W-40
Midland Synqron 5W-40
Motor Gold Mid SAPS 5W-40
Motul SAE 5W-40 Vollsynthetisch
Pento High Performance 5W-40 LA
MB sheet 229.51 approved oils; low ash long life
Mercedes pioneered this new spec for passenger cars with diesel engines with EURO 4 or Bluetec exhaust particle filters and longer service life than the 229.31 oils. The spec was introduced in 2005. Change intervals increased to 20,000 kilometers. Based on ACEA A3 B4 and C3.
Amsoil European Car Formula 5W-40
Anglomoil RoadMaster 500 API SM 10W-40
Aral SuperTronic 229.51 0W-40 LOW SAPS
Castrol Longtec Turbodiesel 0W-30 (229.51)
ELF Solaris LSX 5W-30
Fuchs TITAN GT1 229.51 SAE 5W-30 (first fill oil in OM 642)
megol Motorenoel New Generation SAE 5W-30
Mobil 1 ESP Formula M 5W-40 (to become available in the USA on 5/15/06)
Mobil 1 ESP Formula 5W-30 Emission System Protection (Europe, from 12/05)
Shell Helix Ultra AX 5W-30 Mercedes 229.51
Valvoline SynPower MST 5W-30 229.51 (added 6/1/2006)
