I've been noticing a smell of hot coolant coming from somewhere under the hood of my 96 Sunfire 2.2 I don't see any obvious signs of a coolant leak, nor does the coolant level seem to be dropping by any amount. I do occasionally see drip spots on the ground but I can't tell if they're oil, coolant or some other fluid. The car has very nearly 300,000 kms, but I'm not sure of the motor. When I bought it last year, the previous owner told me he had the motor replaced with a used one (I assume) a few years prior, and at the time I was buying it he told me he thought the headgasket was starting to leak. Maybe now it really is starting to leak?
