Well, if it means anything, I still love 'ya Mola!
The ACEA (Association des Constructeurs Européens d' Automobiles) is the European body of thirteenquote:
satterfi:
It's no wonder why some people think API certification is lame and look for ACEA certification for the oil products they buy.
So if it meets several recognized specs but not API, what does that mean? The API spec is not the "mother" of all specs. Like mentioned before, the oil companies have to pay to have the API label on their product. That does not mean that product won't pass the API tests. It just means they didn't pay for API to say they passed. [/QB][/QUOTE]The specs you quoted means it's most likely a good a oil and the people who make it think enough of it and their customers to get it certified, unlike the botique oils. You picked an oil the represents a small percentage on the non-API oils in the US. Most US non-API oils are botique oils that are not certified to meet any recognized standards. But I said that before, and you choose to ignore it. Which botique oil to you sell? [/QB][/QUOTE]quote:
Originally posted by XS650:
The example you gave meets several recognized specs. Most non-API approved oils in the US are botique oil that aren't certified to meet any significant recognized specs. [/qb]
Originally posted by Brian Reid:
Nothing prevented GM from adding additional specifications over and above the API starburst for the Corvette.
That's right, along with other GM specs, new Ford specs, Dahlmer/Chrysler specs, BMW, MB, VW . . . So why do the manufacturers feel they need to "add additional specifications over and above the API starburst"?
Not really.quote:
thedawk:
"The API Certification Mark "starburst" is designed to identify engine oils recommended for a specific application (such as gasoline service). An oil may be licensed to display the starburst only if the oil satisfies the most current requirements of the International Lubricant Standardization and Approval Committee (ILSAC) minimum performance standard for this application (currently GF-2 for passenger cars).
That's telling me that the API approval is only met if an oil satisfies someone elses (ILSAC) standards."
The Corvette spec was substantially incorporated into the next ILSAC and API standard.quote:
thedawk:
You stated yourself that GM added another spec beyond the API specs. Ford and Chrysler are also doing this. Seems they are heading in the same direction the Europeans are headed.
Maybe the next ACEA rating?quote:
thedawk:
Ford and Chrysler issued specifications in anticipation of pending changes in the ILSAC and API standards. In the case of Ford (and Honda) they had specific fuel mileage and pollution standards they had to fleet certify.
The European situation is much more fragmented.
There is no indication, for example, that the VW TDI specs are going to be incorporated into some future general specification for all European makers.
Read this link: http://www.bullittarchive.com/Maintenance/Oil/quote:
Originally posted by sxg6:
if red line isnt api certified, why do they list a service class? this is an honest question, not being an *** or anything
http://www.redlineoil.com/pdf/4.pdf
http://www.geosc.com/mainpage.cfm?category_level_id=253&content_id=292&channel_id=1quote:
MolaKule:
quote:
The quote from Mobil is old hat. They do use a polyolester in many of their products, called TME. Maybe you could discuss the chemistry of TME and enlighten us.
Yes, it's some kind of a guarantee for us, but 1). approved oils are not 100 % esters, 2). we always want to use the best one, and that's why are herequote:
Originally posted by satterfi:
Then I would suggest that there is nothing wrong with ester based oils since Motul and Silkolene are on MB’s list of approved oils.
I agree. RL/Motul are not 100% ester. We need to keep in mind that their are over 300 different esters or something like that. So what RL is using might be different then Motul etc. I go by UOAs on BITOG for my choices.quote:
quote:
Ester-Diester lubricants have a powerful cleaning action capable of dissolving and suspending harmful sludge, varnish and carbon deposits which keep engines and lubrication ports cleaner and in top performing shape
