I'm looking for a consensus here ... for the best brake pads to use on my 1999 Suburban. The pads are for the front (I have drums on the rears). I'm also open to changing rotors as well. Any and all insights are welcomed and appreciated!
Quote:
I haven't used either of those pads. I would probably try them at some point when I need to replace brakes. One thing to keep in mind is all brake pads have to fall in a coefficient of friction range. Most MFG won't publish that data.
Quote:
. . . except on the side of the pad!
I just bought the cheapest FF pads I could find (Jasper) for the brake pad changes I've done. They haven't been in use long enough to determine longevity, but brake feel was better than with FE pads.
