Gentlemen,
My father-in-law picked up a gently used lawn tractor for me. What a guy! Yardmachines brand, with a Briggs & Stratton engine on it. I've been itching to mow with it, but we've had something of a drought lately, so the grass isn't growing. When you want to mow and the weather is right it doesn't need it, but when you'd rather now, it is ankle high out there. Such is life..
So I thought I would prepare by changing the oil. This is the first tractor or riding lawn mower I've ever owned. There is a drain plug under the hood on the side of the oil sump. If you remove that plug, oil is going to drain all over the side of the mower. So I checked the manual. To get around this problem, it came from the manufacturer with an attachment. I found the manual online and it is called an "oil drain sleeve." Basically it is a little trough that you fit under the drain plug hole. The oil then drains out of the engine, into this trough, and gravity takes its course moving the oil to the drain pan. Well, my second hand mower did not contain this attachment. I checked the yardmachines website. I cold order it for $2.76, but they'd want $8 or so for shipping.
I am sure I'm not the first person who has faced this problem. Is there something y'all are using as a substitute? Can you get a generic one at Lowe's, Home Depot, etc.?
Thanks in advance.
Thanks in advance.
