http://www.mil-comm.com
product TW25B
like mcp's fp-10, their website is good, it provides msds and astm data.
product info: weapons grade all synthetic solvent free grease
astm data doesn't do much for me, if someone else can pull anything worthwhile from it making it a good or bad product then by all means say so.
msds lists the following:
mixture of synthetic oils (esters) and highly refined mineral oils;
calcium sulfonate/carboxylate complex: mixture in highly refined mineral oil.
phosphate ester: < 5mg/m^3
flash point/ autoignition = 475 F
specific gravity: 1.29
http://www.machinerylubrication.com/arti...te%20Thickeners
calcium sulfonate is a grease thickener, it has good EP properties and is more expensive to make than the other greases, lithium for example. But calcium sulfonate greases have been around for a long time, nothing new. In fact, pennzoil marine grease is the same thing.
http://www.pzlqs.com/Tech/Pdsheet/Domest...arineGrease.PDF
So, this begs the question, are you getting anything superior in TW25B, for the price, that you would get from a larger tube of less expensive grease?
TW25b says they use synthetic oils, but are they really needed? And, like with the all the lies about synthetic oils today, how much "real" synthetic oil is in TW25b, because they also say highly refined mineral oil blended in?
Would you be able to use pennzoil grease with no difference in performance?
product TW25B
