http://www.mpclubricants.com/
product = FP-10
product data sheet : http://www.mpclubricants.com/data/data-FP-10military.pdf
msds:
http://www.mpclubricants.com/msds/FP-10.pdf
product info claims a blend of high quality petrochemical products,
contains NO PTFE, NO silicone, no graphite, moly, or solid lubricants.
Flash point 338 F
pour point -49 F
auto ignition temp 469 F
cloud point 14 F
rust preventative (D-665) pass- no rust
kinematic viscosities
100F cst = 25.05 cps
104F cst = 21.7 cps
210F cst = 3.96 cps
212F cst = 3.81 cps
load wear index = 61.33 (4 vall EP D-2783)
last non seizure (sear) 100 kg (0.61mm)
last seizure (sear) 315kg (2.57mm)
weld load 400 kg
odor = cinnamon
msds claims:
66% semi-syn hydrocarbon oil
30% EP oil additive
1% lubricity additive
3% corrosion inhibitor
so, looks like you're buying a quality lubricant (oil). No EP adds it looks like, so I guess you would expect if there's no wet film, there's nothing there to lubricate, no boundary film?
What kind of oils you think they're using? Any oils smell like cinnamon?
can anyone back out the viscosity index based on the kinematic viscosity numbers?
What is "cps" ?
product = FP-10
msds:
Flash point 338 F
pour point -49 F
cloud point 14 F
104F cst = 21.7 cps
210F cst = 3.96 cps
212F cst = 3.81 cps
weld load 400 kg
odor = cinnamon
msds claims:
30% EP oil additive
What is "cps" ?
