Thinking more about moly and galling.... moly may affect the 'SRR', sliding to rolling ratio, where undesireable ratios can result in galling. Since the galling is due to the film thickness being too low, the moly must be affecting the film thickness. The article seems to use a circular argument though, as galling is due to the film thiockness being too low, the film thickness is too low due the traction coefficient being too low, the traction coefficient is dependant upon the viscosity and pressure-viscosity coeffient, which results in a film too thin to prevent galling.
