Griz, your 7.3 turbo is the old style journal bearing type, you have to upgrade to put in a ball bearing turbo. Typical material for these journal bearings from what I can find is brass. At least all the rebuild kits for the Garrett (which you have) turbos I have found include brass bearing inserts.
