Blackstone Labs
2000 Toyota Tundra V-8 (2UZ-FE)
128,042 miles
3,125 mile OCI
Pure One oil filter
NAPA Gold air filter
Pennzoil Platinum 5W30 SM oil used (new formula-non EOP)
Previous UOA's done:
114,973 miles, MaxLife syn 10W30 SL, 5K mile OCI
98,960 miles, MaxLife syn 5W30 SL, 5K OCI
Blackstone's report:
Element/PP5W30/ML10W30/ML5W30/Universal Averages
Aluminum/1/1/2/2
Chromium/0/0/1/0
Iron/3/1/5/6
Copper/2/2/3/4
Lead/8/9/12/2
Tin/0/2/1/0
Moly/49/223/204/58
Nickel/0/0/1/0
Manganese/0/0/0/1
Silver/0/0/0/0
Titanium/0/0/0/0
Potassium/0/0/0/1
Boron/26/7/0/60
Silicon/10/10/9/13
Sodium/2/0/3/10
Calcium/2642/2836/2826/2239
Magnesium/13/11/20/125
Phosphorus/640/688/731/682
Zinc/746/795/808/806
Barium/0/6/0/0
SUS viscosity @210F
/59.7(56-63)/66.2(59-65)/63.9(56-63)
Flash Point/365/>355
Fuel%/ Anti-freeze%/0.0%
Water/0.0%
Insolubles%/0.2/
Blackstone's comments:
JACK: Wear metals read close to what they did in your last sample. However, the wear rate (ppm/mile)
increased and that is a possible sign of some excess wear developing. The universal averages for typical
wear metals in oil from the Toyota 4.7L are based on a 5600-mile oil change interval and lead should
read around 2 ppm. The bearings might be showing their age. The TBN was 4.2, plenty of active additive
left. 1.0 is too low a reading on our scale. Bearings can react differently to different oil. You may want to
try something else then check back for another look.
My comments:
I'm not sure if this is the Techron saga continuing with higher than average lead readings, or my bearings are actually starting to wear. I have re-filled with PP 5W30 and plan to run it 3-5K. My tentative plan is to switch to GC Gold then (already purchased). I've discontinued use of Techron now in both the Tundra and the G35 (40ppm lead on last UOA). We'll see what happens.
128,042 miles
3,125 mile OCI
Pure One oil filter
Aluminum/1/1/2/2
Chromium/0/0/1/0
Iron/3/1/5/6
Copper/2/2/3/4
Lead/8/9/12/2
Tin/0/2/1/0
Moly/49/223/204/58
Nickel/0/0/1/0
Manganese/0/0/0/1
Silver/0/0/0/0
Titanium/0/0/0/0
Potassium/0/0/0/1
Boron/26/7/0/60
Silicon/10/10/9/13
Sodium/2/0/3/10
Barium/0/6/0/0
SUS viscosity @210F
Water/0.0%
Insolubles%/0.2/
My comments:
