So I noticed that the two front turn signals light up different color - one is whiteish, the other - yellowish. Probably the previous owner replaced one of the bulbs and didn't get a matching one.
Anyway, the car is an '02 530i with HIDs; sylvania.com suggests a 7507A bulb for both front and rear turn signals. But I see some websites sell 1156A bulbs instead. Can I use 1156 in place of 7507?
http://www.sylvaniaautocatalog.com/new_s...,18,20,24,25,26
The 1156 seems to have a much longer life but it's also designed for slightly higher voltage (12.8 vs 12). Is this OK?
I don't need any fancy bulbs. Just regular replacements that I can pick up at AutoZone, probably the white version for the front blinkers and amber version for the rear.
Thanks.
Thanks.
