Quote:
Can you lay out the specs? Is this A3 HT/HS 3.5> Elf? Have you changed gasoline? **I'm convinced that the quality of gas varies greatly and impacts performance more than oils. However, if you're going from HT/HS of 3.5 to 2.8, you will notice it.
Fuel was the same tank... unchanged.
Oil seems like it is as thick as GC...so it could be my imagination...but I doubt it... or the explanation might have to do with friction modifiers?
Here's some hype and some specs:
Last product born from the ELF technology in 100 % synthetic formulation, the new lubricant Excellium Full-Tech 0W-30 has been developed in the view to anticipate the major technological trends, in terms of viscosity for example.
Here is thus a product of utmost performances, integrating a transitional physical chemistry between standard technology and low SAPS one.
Perfectly integrated to to environment, it brings the answer to the car-makers newest standards :
ACEA A3/B4-04
API SL / CF
MB p. 229.5
BMW LL01
VW 502.00/505.00
GM LL A025 / B025
RENAULT gasoline and diesel
What to use ELF EXCELLIUM FULL-TECH 0W30 for ? Whatever you search for optimum engine protection, protection against wear and oxidation, engine cleanliness or the utmost reliability whatever the weather conditions : use ELF EXCELLIUM FULL-TECH 0W30, we garantee :
Your engine optimum longevity
A protective film broadcasting on all engines parts allows an utmost protection against wear. ELF EXCELLIUM FULL-TECH 0W30 is thus compatible with the Valvetronic of BMW.
Extra long drain intervals
Synthetic based lubricants' properties entering in the formulation of ELF EXCELLIUM FULL-TECH 0W30 insure an optimum resistance against oxidation
The top level performance and strengh of your engine
Your engine cleanliness is insured by the high performance detergents and dispersants especially formulated for ELF EXCELLIUM FULL-TECH 0W30.
Easy ignition even under cold temperatures
With an optimum viscosity running till -54° C, ELF EXCELLIUM FULL-TECH 0W30 insures an excellent quality even at low temperatures. Besides, high temperatures performance is also something in which you can trust ELF EXCELLIUM FULL-TECH 0W30, of astonishing thermic stability.
Fuel saving
The fluidity allows to the reduction of engine frictions thanks to the optimized oil film thickness. ELF EXCELLIUM FULL-TECH 0W30 which does not so to say belong to the "Fuel Economy" lubricants, obtains results close to this range.
... And environement friendly
With low ashes and phosphorus levels, ELF EXCELLIUM FULL-TECH 0W30 is also a transitional product between standard technology and low SAPS one !
http://www.elfmoto.us/lub/lubusa.nsf/VS_OPM/C125717D00402081C12571B6004A2246?OpenDocument
http://www.elfmoto.us/lub/content/NT0007E962.pdf
Viscosity at 40C 68.45
Viscosity at 100C 12.18
Viscosity Index 170
Pour Point -54C
