I have a post in the Mechanical forum about a oil pressure problem in my 94 Toyota Camry. I am starting to think the problem is a sticking oil pressure relieve valve given the symptoms. (Start engine cold , pressure goes to 15 lbs and stays regardless of RPM. Turn engine off then start again and pressure runs between 20 and 50 depending upon RPM. This has happened the last two mornings I have tried it with my mechanical gauge installed).
So I am thinking I have something (sludge, varnish) in the oil pressure relief valve causing it to stick.
What to try to clean things, MMO or Amsoil Flush or AutoRx. Maybe one for the short term and another product for the longer term?
Can it be cleaned by any flush or cleaner?
