Yesterday was my first time under a 2007 Toyota RAV4. It was a snap to change the oil and filter (dropping the factory fill at 1000 miles). However, I saw grease fittings on the ball joints and steering arm but no way to lube them. Usually when I see the rubber seats on a lube point, there's a nipple (e.g., a zerk fitting) to attach the grease gun. I searched visually and with my fingers all over the area of the fitting, and couldn't find where to attach the grease gun.
I know that some fittings are sealed (so-called lifetime lubed), but I've never seen that with those that had the rubber seats.
How do I lube these lube points--or do I?
