I think the general consensus here and on other Toyota boards is that 75w-90 will be good anywhere SAE 90 is spec'd because the multi-weight will be approximately the same viscosity at operating temp.
Toyota is not keeping up with the gear lube specs as evidenced by the fact that they made no changes to thier recommendations when the specifications have changed substantially. They probably see no need since they are building solid products and are focusing resources on becoming the global #1. At the time the SAE 90 spec originated the straight weight may have been a more robust product because it lacked VIIs. This is no lomger the case.
I like the Amsoil 75W-110 for this application and will go to it in the rear of my Lancruiser at the next change.
