Let's say we have a tire with an overall diameter of 25". From this we can calculate that the circumference is about 78.5". But once the tire is on the car, will one tire rotation result in a distance traveled of 78.5" or something less than that because the sidewall is a bit flattened? Another words, a radius of a tire off the car and on the car is not the same, correct?
I noticed some manufacturers report a value called "static load radius":
http://www.bridgestonetire.com/tireselector/dpp/sizespecs.asp?passproductid=1113
How do I interpret this value?
Does changing PSI in the tire by 5 or 10 affect the rolling radius?
I got into an argument with someone that great changes in PSI will affect the distance traveled during one full rotation. He claims that the amount of tread in a tire is fixed, say a slab of 78.5" in length, and since all of this tread has to make one full rotation, the distance traveled will not fluctuate with PSI or load carried. I understand what he's saying, but then again, we're talking about rubber here - a flexible material that can stretch and contract, different tread blocks coming together and moving apart as the tire flexes. I thought that causes the distance traveled to vary.
Capri, can you shed some light on this?
Thanks.
Thanks.
