Quote:
......Do different pavement compounds cause noticeable differences in fuel economy? Just curious...
If you are asking if different paving surface materials affect fuel economy, I think the answer is yes, but the effect is slight - which I will explain below.
If you are asking if different tread compounds affect fuel economy and that can be tied to the friction of the tire to the road surface.....ah..... it's more complicated than that.
The vast majority of resistance to rolling in a tire comes from friction within the tire itself.
This means the amount of deflection a tire experiences has a major effect - this equates to inflation pressure vs load.
This also means that the amount of material, especially material in the tread area, will also have a major effect. So All Terrain tires will have higher RR values than All Season tires - everything else being equal - which is usually not the case.
But the tread compound also has an effect. There are three properties that get traded off - RR, traction (especially wet traction), and wear. This means that tires that give good RR, generally don't have good traction or wear (or both), which is why you'll hear these types of complaints on Original Equipment tire, where the car manufacturers have to get CAFE fuel economy number and have the tires compounded to help.
High Performance tires generally have cap plies, which adds to the mass in the tread area, as well as having good traction compounds - which don't wear well and have poor RR values. I think this is where the myth of "friction with the road surface causes RR" comes from. The friction with the road surface contributes very little to RR compared to the deflection of the tire.
OK, now to the road surface.
Believe it or not, road surfaces flex under load - asphalt more than concrete. Needless to say this is very similar to what happens when a tire flexes, but to a much smaller degree since the deflection is much smaller. This should result in heat buildup in the road surface - and probably does, but I would think it would be so small that it would be difficult to measure.
And, of course, we can measure the heat build up in a tire by measuring the pressure buildup.
